[Geoserver-devel] Some rest debugging headaches
I was writing some tests for the simple feature service implementation
when I got tangled up in a separate issue... the basic test I wrote
was failing to build a valid response, but the response status I got back
was a 200 and just a "[" as the content of the response.
No logs, no way to know what happened.
After some debugging I found that Restlet logged the exception that
was thrown only at the INFO level, which is disabled during tests,
and that it did set the status to 500, but too late because the response
was already committed.
For the first issue I'm attaching a patch that seems to solve it:
the ServletConverter gets subclassed to override the logging level
of the error to SEVERE.
For the second one (setting the status before commiting the request)
I guess we should have a output strategy
handling on the rest path, so that we cache some kb of data before
sending back a response.
I _think_ this may be doable by wrapping the httpservletresponse
into one that would build a stream backed by the output strategy
Opinions?
Ing. Andrea Aime
Technical Lead
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
(attachments)
log.patch (2.88 KB)
On Sun, Jan 30, 2011 at 4:16 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
was a 200 and just a “[” as the content of the response.
For the first issue I’m attaching a patch that seems to solve it:
The only issue I see with raising the logging level might be that exceptions written out when it is not wanted. The rest stuff makes use of exceptions to report back specific error codes. However in most cases it is an error case… like a 404 when asking for a resource. But one could send back any error code via an exception in non error cases.
That said we don’t really have a way to differentiate so just raising the level is fine. Better to give more information than less :slight_smile:
I think this may be doable by wrapping the httpservletresponse
Seems like a good idea, +1
Opinions?
Ing. Andrea Aime
Technical Lead
fax: +39 0584962313
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
