Got further and think I have a solution. Happy to get feedback, it has been a while since I've actually coded something this way :).
Note: worked on a fork of the geoserver code, for now in the 2.1.x branch, because I need a fix here. See https://github.com/thijsbrentjens/geoserver/commit/ba5c0ecb1cc72878b2bdd3db84239d30eb779000 for changes. Should work for other versions as well.
Background. The problems with XSS vulnerabilities arise here:
1. In ServiceExceptions for OGC-style services (wms, wfs etc) the vulnerability for XSS exists, because of reporting back the input in the exceptiontext and the locator-part of the exceptions un-encoded.
2. In the WMS OpenLayers outputformat XSS vulnerability is caused by writing the request parameters directly (unescaped) in the JavaScript output as specified in the Openlayers template. http://jira.codehaus.org/browse/GEOS-5318
3. through GWC WMTS and WMS interface. Exceptions are reported a bit differently here. Bug report: http://jira.codehaus.org/browse/GEOS-4210, but found some other XSS vulnerability.
4. in the web-admin. For the projects where I work on, the XSS vulnerability in the web-admin is less relevant, since the webadmin is not accessible publicly.
I have fixes available for 1 to 3. I haven't got time for 4., but hope my examples might help others if needed. The OWASP encoder (https://www.owasp.org/index.php/OWASP_Java_Encoder_Project) library seemed very useful to me. It provides encoders for several context as they call it. E.g. for XML output, HTML or JavaScript. To me it looked the easiest and most reliable for encoding. The OWASP website also provides lots of information on XSS and other vulnerabilities.
What I did:
1. in the platform, ows and wms packages: add the OWASP encoder library for encoding easily for different context (e.g. encode for HTML, XML or JavaScript)
2. changed ServiceException.java: make sure that the exception text and locator are encoded for output in XML (as text and attribute).
3. in the OpenLayersMapOutputFormat class: encode the input parameters for JavaScript output.
4. in util.OwsUtils added encoding for error messages, for all messages, to make sure they are encoded properly (this makes sure that XSS does not work with something like: http://localhost:8080/geoserver/gwc/service/wmts?request=""/><axmlns:a='http://www.w3.org/1999/xhtml'><a:body%20onload="alert('xss')"/></a> )
Hopefully the code is clear. I used a less elegant solution first for the ServiceException class (that is in an earlier commit), please be aware of that when looking at the differences compared to the original 2.1.x source.
Probably, it could be done better or improved somewhere. I have done several tests (for XSS), but would really like more (functional) tests for the OpenLayers preview. For my cases it works fine though. Am very curious if it's okay for you and usable for others as well.
So please feel free to try and give any feedback! And if I can do anything to help it further, just let me know.
Thijs
On 13-03-13 12:02, Thijs Brentjens wrote:
Hello Gabriel,
Thanks for looking it up and pointing to the code! For the SRS parameter
the solution you implemented seems to be good. The thing is, other
(invalid) input could also be used for XSS.
If you would send this request to a Geoserver instance:
http://localhost:8080/geoserver/gwc/service/wmts?request=<a
xmlns:a='http://www.w3.org/1999/xhtml’><a:body onload="alert('xss')"/></a>
the script gets executed. So the request-parameter is vulnerable (SRS
seems okay). In fact, most WMTS parameters seem to be vulnerable. I took
a valid, working WMTS request and replaced several parameter values
(like the format, request and tilematrixset params) with the value in
the example above ( <a .... etc ... </a> ). If you execute that, the
service exception triggers browsers to execute the script.
If the exception report would HTML encode the input value of the
parameter (if reporting it) that caused the exception, it should be fixed.
The website
https://www.owasp.org/index.php/XSS_(Cross_Site_Scripting)_Prevention_Cheat_Sheet
lists some measures that could be taken for all kinds of XSS. I think
for Service Exceptions there is no need to cover all defenses. HTML
encoding would do (there is no data input through CSS in a Service
Exception for example..) because the input values are only reported in
the "body" of the service exception. But I'll check that.
I also just found a WMS vulnerability, in Geoserver 2.2.4. Just to be
sure: the best would be if all Service Exceptions (in fact: all
exception reports that report back the input) would always encode any
input parameter before writing the exception, that would fix a lot of
issues.
I'm happy to help (will try something soon ) and provide more test
requests. Not sure if sending these on the mailinglist is such a good
idea (from a security point of view). So let me know.
Thanks in advance!
Thijs
On 13-03-13 04:15, Gabriel Roldan wrote:
Hello,
re GEOS-4210, this is the commit I meant in the comment
<https://github.com/GeoWebCache/geowebcache/commit/f4b3d357533b8ba1f05965fc57098bb5250b067b>
Looks like I was too lazy at the moment as to chase it down but its
easier with git now.
The way I understand it is that an exception will be thrown when
attempting to parse the SRS parameter which ultimately will be handled
by that writeError method in GeoWebcacheDispatcher. If you can confirm
that's not what's going on and the XSS vulnerability exists while
calling a gwc service I'll be glad to look deeper into it.
Gabriel
On Mon, Mar 11, 2013 at 2:13 PM, Thijs Brentjens
<lists@anonymised.com> wrote:
re 1):
There is/was some discussion on XSS already, I noticed:
http://jira.codehaus.org/browse/GEOS-5318 --> still open
http://jira.codehaus.org/browse/GEOS-4210 --> says for GWC a fix has
been done a while ago.
From another source:
http://itsecuritysolutions.org/2012-04-13-ActiveX,-Remote-DoS-and-XSS/,
also lists some XSS vulnerabilities for GS 2.1.4
Summary: in 2.1.x XSS can be used by exploiting the Service Exceptions
for WMS and WFS. This is confirmed in our test. In 2.2.x this seems to
be fixed already for WMS and WFS. However 2.2.x versions still are
vulnerable. For example: WMTS by GWC is vulnerable,
xmlns:a='http://www.w3.org/1999/xhtml’><a:body onload="alert('xss')"/></a>.
Before I get my hands dirty myself: has someone a solution available
maybe (I can't see any activity now, but you never know) or knows of
something? Or can someone point me to where the fixes between 2.1 and
2.2 have been done to avoid XSS? Maybe I could use that for my client
(and in the end others) and use it to fix some other XSS issues as well.
If not, I'll dive into the code :).
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
Geoserver-devel mailing list
