[Geoserver-devel] some thoughts on Operations and company
Gabriel and I have been having good design discussions about the
dispatch system on 1.5.x. I think its time to bring it out publicly.
Gabriel,
You make some great points. However, the intent with the request object
parsed from xml is that the user will probably have automatically
generated it from an xml schema, so that they don't have really have to
to maintain the request object.
If I understand it correctly, you are suggesting a solution from the
opposite angle. Instead of having all the properties on the operation,
make it on the request object and the operation only depends on the
request object. I thought about this solution as well.
I do very much like that this makes the operation stateless. I also like
the original solution due to the fact that it is one less level of
abstraction. All the information is present on the operation and not
through the request object.
So I am a little torn about this. Perhaps Jody who helped me with the
initial design can provide some feedback.
To help bring people into this discussion, I have started an article
outlining my vision of what developing services with geoserver should
look like. It is not complete, but outlines the design of the dispatch
system we are talking about.
Let us see if we can get any more information.
Gabriel Roldán wrote:
Making the dispatcher set the operation properties from the request object
sounds good, but still doesn't solves the burden of having to take care of
each operation parameter in two places, even if one of them is automatically
handled by the dispatcher, one have to maintain a name/type attribute
consistency for each one.
By the other side, it would be more elegant if an Operation were stateless,
and a lot clearer if it only has one operation method if a "value object"
parameter instead of having to populate the operation with multiple calls.
This is, I would prefer to follow the value object pattern so an operation's
parameter is a single object encapsulating the request state.
Is it making any sense? going too much against your original design idea?
would it be possible, using some spring magic, to create a request object
from the kvp readers, just like we create it through the xml parsers?
Gabi
On Monday 18 September 2006 22:28, Justin Deoliveira wrote:
The idea is that for a post, instead of the dispatcher directly calling
the operation with the request object, the dispatcher would inspect the
request object for its properties and use reflection to set the
associated properties on the operation. The operation never has to know
about the request object. Does that make sense?
Thanks for this feedback, it is very much appreciated as this stuff is
still very young. It would be also good for use to have some of this
conversation on the list as well so that other people can start getting
exposed.
-Justin
I'm working on the GetRecords operation for CSW. Got the kvp parsers and
the like, but I'm having a feeling that something is not as good.
As I see it, both the kvp reading process and the xml request parsing
should produce the same "request" object. Nowadays, the kvp reading sets
properties on the Operation and the xml request parsing produces a
"request object". This means that for each request attribute I have to
add a property to the operation inside each setter update the related
property on the request object.
I know I'm being a bit lazy about the terminology used, it's just that
I'm still recovering from the trip :slight_smile:
The point is that I would like to avoid this duplication and thus let the
operation be cleaner. Do you know if that would be possible with the
current infrastructure?
Justin Deoliveira
jdeolive@anonymised.com
The Open Planning Project
http://topp.openplans.org
Woot! Public discussion :wink:
Gabriel,
Oh darn, inverse order email stack problem .... (turning things around the other way around, and replying in order)
Nifty, my sanity check should be that the GetRecords opperation should not need to see any explict KVP code.
Thinking about that. I would break things down at one level - so as to appear more "sane" to the casual Java programmer.
Let me try to explain where I think we are right now :slight_smile:
- XML Schema used to generate a
- Java Bean (aka the request object)
interface GetMap {
     ReferencedEnvelope getBBox(); // required
     List<Layer> getLayers(); // required
     List<Style> getStyles(); // optional
    String getHandle(); // user supplied used for error reports
This can be filled in via:
1) GTXML parser binding(s) - yeah!
2) WKT "bindings" (seems Justin did this based on java class?)
At the "end" of the day (ie during a request) we end up with one big Java Bean, with full documentation from the original XML schema.
This has some consequences:
- anything that is not in the WKT must be "optiontional" (ie allowed to be null) in the java bean
- hopefully if the request xml schema is good this will agree with the XSD idea of optional
  (ie we should be able to check what WKT is optional from the XSD)
We have a couple options on how to take this to our simpel "Pojo Service":
a) request bean approach:
interface WMS_1_3 {
     Image getMap( GetMap request );
b) method reflect approach:
interface WMS_1_3 {
     /* most direct request */
     Image getMap( ReferencedEnvelope bbox, List<Layer> layers);
     /* start mixing in optional parameters */
     Image getMap( ReferencedEnvelope bbox, List<Layer> layers, List<Style> style, ...., String handle );
So we have a couple implementation options (which Justin and Gabriel are trying to sort out what will be easiest in the long term).
Reference:
a- receive request -> unpack request -> dispatch -> handle request -> package result -> response
Implementation Options:
b- HTTP GET Request -> KVP Brindings -> create GetMap bean and set properties -> WMS.getMap( GetMap bean)
c- HTTP GET Request -> KVP Brindings -> refelct on WMS service bean -> WMS.getMap( bbox, layers, service, handle )
d- HTTP POST Request -> GTXML Bindings parses into a GetMap bean -> WMS.getMap( GetMap bean )
e- HTTP POST Request -> GTXML Bindings parses into a GetMap bean -> reflect on GetMapBean and "dispatch" to reflected method -> WMS.getMap( GetMap bean )
f- HTTP SOAP Request -> ???
g- JMS Message -> ???
Q&A on the details:
- do we need a GetMap bean? yes, to represent the Post request, also useful to hold data for validating the request
- do we always need a "request" bean? probably not - simple KVP services should be happy
So where is the conflict (ie what are justin and gabriel talking about?) It comes down to option d) vs option e)
- do we just use the GetMap bean as a stepping stone (and ask the framework to reflect on both bean and service?)
- do we just reflect on the services and see who can handle the GetMap bean
Note on Scope: The GetMap bean is actually specific to a specification (WMS1.0 GetMap bean != WMS1.3 GetMap bean). Framework handles "version negotiation" as part of the GetCapabilities opperation we do not need to worry about this when handling a request :slight_smile:
My rough feeling is that Justin (ie framework) can take on any amount of pain to make it easy for Gabriel (ie service writers) to work. I am really happy that they are both sorting this out at the same time (it will keep both honest).
Lets's see how my rough understanding plays out in their email :slight_smile:
Erk - perhaps we should *always* go through the bean (even if only to isolate the .isValid() check)?
Heh, nobody is recovered.
Unsure, I think we can get their via reflection (and a few of Justin's braincells).
Justin replied:
I see, so my big overview is wrong :frowning: I was hoping the "dispatcher" would play with method arguments, it seems
that these may be handled as service attributes.
exposed.
-Justin
Making the dispatcher set the operation properties from the request object sounds good, but still doesn't solves the burden of having to take care of each operation parameter in two places, even if one of them is automatically handled by the dispatcher, one have to maintain a name/type attribute consistency for each one.
Trying to understand the duplication of effort ....
- is keeping the same name between method attribute (or is it operation property) and request property the problem?
  (I would ask that we take this pain as it provides a lazy way to document via reference to original schema)
By the other side, it would be more elegant if an Operation were stateless, and a lot clearer if it only has one operation method if a "value object" parameter instead of having to populate the operation with multiple calls.
This is the "conflict" I had w/ the FROG project, it is much nicer to reuse your service by making each reqeust/response isolated.
So:
- isolated: WMS.getMap( GetMap request )
- isolated: WMS.getMap( ReferenceBounding box, List layers, List styles, ..., String handle )
- non isolated:
interface GetMapOpperation {
      void setBBox( bbox );
      void setLayers( List layers );
      void setStyles( List styles );
      Image opperate();
Something that could help (but hide) the problem is:
      setRequest( GetMap request ); // unpack the request
      Image opperate();
Something that would be "evil" is:
interface GetMapOpperation extends GetMap { // has defined the get/set methods already
      Image opperate();
This is, I would prefer to follow the value object pattern so an operation's parameter is a single object encapsulating the request state.
I agree with the value object, and the single value object (so we can check isValid), but I would like to offer isolation
by explicitly providing normal methods (making this API approachable to the casual java programmer who is comparing
us to a SOAP toolkit and finding us wanting)
Is it making any sense? going too much against your original design idea? would it be possible, using some spring magic, to create a request object from the kvp readers, just like we create it through the xml parsers?
I understand, it is a tradeoff, I like the idea of going to the request object to feed the framework, and then asking the "dispatcher" to do the reflection
crazyness at the method level.
Justin then punted us onto the email list ...
Check.
I think we got the hang of what Gabriel was suggesting.
So how about my "middle ground", where the operation is stateless, the arguments capture the elements from the request, and the bean is used as a carrier between the parser and the dispatch system?
I know this does not promote "perfect" reuse but the following *should* be considered in order to compete with the WSDL/SOAP solutions:
Option Gabriel:
interface WMS_1_3 {
      GetCapabilities getCapabilities() throws ServiceException;
      Image getMap( GetMap request ) throws ServiceException;
      Object getInfo( GetInfo request ) throws ServiceException;
      List getStyles( GetStyles request ) throws ServiceException;
      List putStyles( PutStyles request) throws ServiceException;
Option Jody:
interface WMS_1_3 {
      Image getMap( ReferenceBounding box, List layers, List styles, ..., String handle )
      Object getInfo( ReferencePoint location, ... );
      etc
What both gabriel and jody are missing is the "context" from the HTTP request (ie client lists accepted formats as part of the HTTP request). Throwing this into the parameters is not fun, attaching it to the request bean is okay, setting these as properties makes stateful.
Well here is a big whack of an email :slight_smile: Help it is not ...
Will be fun to compare this email to your article.
Look at prior art, SOAP/WSDL and make sure we are "easier". Note easier can be done with super class if needed.
Jody
after have thinking a bit on this issue, with the information I have right now, I think the Gabriel proposal is the better one.
Basically heavily using reflection, the dispatcher will bring up the request and build the appropriate validated request object, then it will pass it to a stateless operation class, which will modify his behaviour against the previous request object properties.
So we could have at the end a parsing and validating system both for KVP and XML request types, and then a dispatching system that instantiates the operation using relfection to let her building the right response.
We could even use the Spring application context to register the operations and let the dispatcher automatically found the right one to be instantiated. Does it make sense?
Maybe we may build a list of pros and cons for both solutions in order to have a more precise idea of the problems adopting one or another.
Gabriel,
Oh darn, inverse order email stack problem … (turning things around
I’m working on the GetRecords operation for CSW. Got the kvp parsers and
the like, but I’m having a feeling that something is not as good.
should produce the same “request” object.
appear more “sane” to the casual Java programmer.
  • XML Schema used to generate a
  • Java Bean (aka the request object)
    interface GetMap {
    List getLayers(); // required
    List getStyles(); // optional
  1. GTXML parser binding(s) - yeah!
  2. WKT “bindings” (seems Justin did this based on java class?)
At the “end” of the day (ie during a request) we end up with one big
  • anything that is not in the WKT must be “optiontional” (ie allowed to
  • hopefully if the request xml schema is good this will agree with the
We have a couple options on how to take this to our simpel “Pojo Service”:
interface WMS_1_3 {
interface WMS_1_3 {
/* most direct request /
Image getMap( ReferencedEnvelope bbox, List layers);
Image getMap( ReferencedEnvelope bbox, List layers,
List style, …, String handle );
Reference:
a- receive request → unpack request → dispatch → handle request →
package result → response
b- HTTP GET Request → KVP Brindings → create GetMap bean and set
properties → WMS.getMap( GetMap bean)
c- HTTP GET Request → KVP Brindings → refelct on WMS service bean →
d- HTTP POST Request → GTXML Bindings parses into a GetMap bean →
e- HTTP POST Request → GTXML Bindings parses into a GetMap bean →
reflect on GetMapBean and “dispatch” to reflected method → WMS.getMap(
GetMap bean )
f- HTTP SOAP Request → ???
g- JMS Message → ???
Q&A on the details:
  • do we need a GetMap bean? yes, to represent the Post request, also
  • do we always need a “request” bean? probably not - simple KVP services
    should be happy
  • do we just use the GetMap bean as a stepping stone (and ask the
  • do we just reflect on the services and see who can handle the GetMap bean
(WMS1.0 GetMap bean != WMS1.3 GetMap bean). Framework handles “version
negotiation” as part of the GetCapabilities opperation we do not need to
Lets’s see how my rough understanding plays out in their email :slight_smile:
“request object”. This means that for each request attribute I have to
Erk - perhaps we should always go through the bean (even if only to
I know I’m being a bit lazy about the terminology used, it’s just that
I’m still recovering from the trip :slight_smile:
Unsure, I think we can get their via reflection (and a few of Justin’s
braincells).
Justin replied:
I see, so my big overview is wrong :frowning: I was hoping the “dispatcher”
exposed.
-Justin
sounds good, but still doesn’t solves the burden of having to take care of
Trying to understand the duplication of effort …
  • is keeping the same name between method attribute (or is it operation
and a lot clearer if it only has one operation method if a “value object”
This is the “conflict” I had w/ the FROG project, it is much nicer to
So:
  • isolated: WMS.getMap( GetMap request )
  • isolated: WMS.getMap( ReferenceBounding box, List layers, List styles,
    …, String handle )
  • non isolated:
Image opperate();
Image opperate();
Something that would be “evil” is:
methods already
Image opperate();
This is, I would prefer to follow the value object pattern so an operation’s
object to feed the framework, and then asking the “dispatcher” to do the
reflection
Justin then punted us onto the email list …
generated it from an xml schema, so that they don’t have really have to
Check.
So how about my “middle ground”, where the operation is stateless, the
I know this does not promote “perfect” reuse but the following should
Option Gabriel:
interface WMS_1_3 {
Option Jody:
interface WMS_1_3 {
…, String handle )
Object getInfo( ReferencePoint location, … );
etc
What both gabriel and jody are missing is the “context” from the HTTP
Well here is a big whack of an email :slight_smile: Help it is not …
Look at prior art, SOAP/WSDL and make sure we are “easier”. Note easier
Jody
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys – and earn cash
Geoserver-devel mailing list
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Agreed, I think we are all in the same spot (especially after finding out argument names are not available via reflection).
Creating the request bean should not require much in the way of reflection ...
- for HTTP POST GTXML will produce the correct request object out of the box based on schema binding
- for HTTP GET the SERVICE/REQUEST/VERSION (part of every OWS request) uniquely identifies a request for OWS POST/GET
- (SOAP also is very explicit about the end points it will hit)
Setting the parameters on the bean will require reflection for HTTP GET and SOAP.
Dispatch could be via reflection, if we had an OSGi style XML fragment to parse it would be even better (since we only need to create these operations beans when they are used for the first time).
It is also worth pointing out that the end result is rather similar to what the FROG project came up with, the difference being we are using Spring and reflection to make the whole thing easier to use (the actually mentioned the "bean" as part of their request url).
Jody
It looks like this method is the preferred one. There are a couple of
more issues I would like to bring up, resulting from my experience in
using this system with ows4.
First is that a request object introduces another level of indirection
between the user and service. If I want to instantiate my service and
go, i also need to instantiate a request object.
Since ideally these request object are being generated by some xml
schema to java generator, it will be hard for the dispatcher to
automatically create and instantiate these things. Like with emf having
to use an emf factory. So its one more thing the user has to do when
creating there service, is register the factories or whatever used to
create request objects.
The third issue is with scalability. Suppose I want to access to the
output stream that the request is running against ( useful for services
that stream content ). Or some other property that isn't part of the xml
schema defining the request. How does this slot in. With the property
based system it is easy, just add another property for the output
stream. However what does this look like for the request object. We
could do something like allow the operation to declare the output stream
as a method parameter, but things start to get a bit blurry since the
request object isn't extensible.
Anywho, just some food for though. Another option that we might consider
is giving people the ability to choose which system they want to use.
-Justin
Jody Garnett wrote:
right
request
it to
reflection ...
and SOAP.
KVP and
operations
instantiated
Jody
!DSPAM:1004,451aa74b144102095110867!
Justin Deoliveira
Just keep in mind that too much choice can be bad. Ideally we should decide on one default, recommended, documented way of doing things. And then maybe offer another way if some people really want it, but stick with the main way. Most people will be looking to how we do the main services if they're building their own, so we should have the core ones and additional ones we build be consistent.
Chris
-Justin
Jody Garnett wrote:
right
request
it to
reflection ...
and SOAP.
KVP and
operations
instantiated
Jody
Chris Holmes
