Hey all,
so I've been looking at how to have GeoServer automatically switch to HTTPS when user credentials are on the fence and/or when we do have
possibly sensible information running over the wire.
The two use cases I have in mind are:
- admin console, whenever an administrator logs in and edits
store/layer information, that should happen over SSL
- any data transfer that requires the user to authenticate
(meaning that the user credentials are stored in http basic
authentication headers, and that the information being
transferred might be sensible as well).
So basically what seems to be needed is:
- have the authentication form post to an HTTPS url
- have all secure pages force a redirect to HTTPS if they
are hit thru a non secure URL
- have all OGC service requests using http basic authentication
switch to HTTPS by default
- have the responses asking the user to authenticate using
HTTP basic include a redirect to HTTPS first (that is, first
redirect to HTTPS, then tell the client that the user does not
have enough credentials and ask for them using a HTTP 401
response. At that point the browser will pop up a user
credential request, but the whole communication will be
switched to https already).
Am I missing anything?
There are two more things to discuss. The first is that the
container might not have SSL enabled. Acegi has a class
that performs redirection only if SSL is there, but it
requires one to configure the SSL ports in the application
context... bah! Not very useful as people can be using
custom ones... I'll have to find a way to make this runtime
configurable (maybe turn it into a GeoServerInfo parameter?).
The second issue is, what do we do for development and
demo (release) purposes? Setting up a SSL layer requires
one to create a certificate, a keystore and whatnot.
This guide provides some hint:
http://docs.codehaus.org/display/JETTY/How+to+configure+SSL
I would say that for development purposes we should setup
a keystore with a well known setup and give Start.java
an option to use it, so that we can do tests with both
SSL enabled or not. The certificate will be valid for localhost
only, maybe the browser will get grumpy the first time and
ask us if we want to really trust that self signed certificate,
but from there on it should be smooth ride.
What about release? The Jetty configuration we ship with
actually has a keystore ready, one just has to include
the jetty-ssl.xml config file in the command line. Try
with:
java -DGEOSERVER_DATA_DIR=... -jar start.jar etc/jetty.xml etc/jetty-ssl.xml
and then try to connect to http://localhost:8443/geoserver
and you'll see.
We could just enable this by default but... as Arne pointed
out, it would give people a false sense of security,
since everybody knows the private key of that certificate
so it's possible to hijack those ssl communications without
much effort.
The only way to get real security is to have people
buy/create and install their own certificates...
Opinions? Help very much appreciated, I'm no security expert
