aaime@anonymised.com wrote:
here are some random things I've noticed while reading the WMS spec.
Note I'm not a WMS spec expert, at least not in the same way as I know wfs backwards and forwards.
1) AUTO CRS does not seem to be supported?
As far as I know, no. I never dug in to figuring out how this worked, and no one's seemed to have requested it.
2) I don't see any usage of the updateSequence parameter in getCapabilities,
yet it seems to be important for capabilities caching (uDig has problems
with cap caching afaik).
No, we don't use it. There's a bug in jira to support this. I suppose we'd do it by whenever there's a 'apply/save' in the web admin? I never thought of the use case of caching, which makes sense.
3) Contact information can be entered into a configuration page, but
it's nowere to be seen in the getCapabilites outputs?
Yeah, that's a bug, that worked before. Go ahead and file it and investigate where the problem might be if you have time. I think something's just not propagating right.
4) No metadata URL... it may be that a WMS layer is described in
an external catalog... the same applies more or less to lots
of other WMS layer specific parameters, it seems there's no way
to specify them?
Yeah, there's a jira for this too. Have been meaning to add it for awhile, haven't had the time. It's quite important to be able to do this actually.
5) Cascading WMS... Seems a little crazy to me to try
and reproject a map that's already been styled and labelled, reprojection
at the drawn map level will simply ruin everything...
I think what you'd do is maybe just not offer reprojection on that layer? Or offer it and recommend against it. But we have no immediate plans to support it...
Chris
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-devel mailing list
!DSPAM:1003,45212f23288501775926497!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
