Hi Andrea,
I took the new process selection stuff for a spin today and noticed some issues. I have a pull request with some fixes.
https://github.com/geoserver/geoserver/pull/15
Here the individual changes in detail.
First issue was that i noticed that the spring factory was not loading. Cause was it was being registered after the initial initialization of the WPSInfo.getProcessGroups() property. I think this change fixes the current build failures as well.
https://github.com/jdeolive/geoserver/commit/2509c8ca2da39d01ede7579c2f79c9e7dc796c6d
Second issue was that no initialization of the WPSInfo.getProcessGroups() property was happening in cases whether wps configuration is created from scratch. I moved the initialization out from the bean object and into the loader which seems more inline with trying to keep Info objects as dumb beans.
https://github.com/jdeolive/geoserver/commit/d408809016eb902d5dc62d8f86ba829f28db4ee2
The rest is minor stuff.
Making WPSInfo property/setter consistent with getter.
https://github.com/jdeolive/geoserver/commit/b3b1be84846a2e5a07b371a83352e7ebb253fd60
Dropping “info” suffix from xstream representation which we generally don’t include with the other Info object aliases.
https://github.com/jdeolive/geoserver/commit/d09378fa27a5a71705839df738bd41621be455d0
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
On Mon, Aug 13, 2012 at 4:31 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Andrea,
Forgot a commit for this one as well.
https://github.com/jdeolive/geoserver/commit/e6b13ace72dc60c05444cd07b12a67852b29e7ee
-Justin
Justin Deoliveira
Justin Deoliveira
On Tue, Aug 14, 2012 at 12:31 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Andrea,
That’s odd, there is no build failure (the one from yesterday was due to the UI frontend changes).
Looking at the changes, I believe this might be due to a different filesystem layout that makes
Spring load the beans in a different order.
The change is fine by me.
Hmm… that’s problematic as well for two reasons:
- that initialization won’t happen for people upgrading from 1.7 (people upgrading from 1.7 with WPS? As incredible as it may sound, I’ve seen a couple)
- the initialization might happen too soon and miss factories that register programmatically on startup (all the spring based ones do),
with the result that the GUI won’t offer a way to configure those
Maybe we should move it to a GeoServer initializer or a lifecicle listerer?
That way we could have a way to also update the configuration on a “reset” and 2reload" and add
feature factories that might have popped up in the meantime
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
On Tue, Aug 14, 2012 at 2:34 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Andrea,
It was just a guess, looks like it wasn’t the case but Ben sorted it out.
Works for me. There already is a WPSinitializer class so we could potentially move it there.
As for picking up new factories i am not sure how that would work since the process groups are only added if the WPSInfo.getProcessGroups() property is null… if it has a value we leave it as is right? Maybe we could add something to ui which would basically be a reset that would clear the current groups and reinitialize from all found.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
On Tue, Aug 14, 2012 at 3:47 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Ah right, Martin’s changes to the vector process metadata.
What we could have is a GeoServerLifecycle listenter that’s somehow tightly coupled with WPSInfo, on a reset or reload call
it would take the existing process groups, compare with factories coming from Processors, and add the missing ones.
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Aug 14, 2012 at 8:25 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ahh ok, i thought that the lack of a process group info object meant it wsa disabled, but there is an explicit flag for that cool. Ok, so updated the pull request with this change.
https://github.com/jdeolive/geoserver/commit/7ba804e07340aabc40cf65c791130f6cf459d08b
And have tested that the upgrade works post and pre 2.0.x (ie 1.7.x upgrade) and also verified a reload works. Ok to merge?
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
On Tue, Aug 14, 2012 at 5:48 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Yep thanks!
Ing. Andrea Aime
@geowolf
Technical Lead
