I know geoserver.org is on github pages, but I'm not finding the source for
docs.geoserver.org
The download link is different to the other Geoserver sites.
Any suggestions?
Brad
docs.geoserver.org
Any suggestions?
Brad
https://github.com/geoserver/geoserver.github.io
On Tue, May 31, 2016 at 9:33 AM, Brad Hards <bradh@anonymised.com> wrote:
I know geoserver.org is on github pages, but I’m not finding the source for
docs.geoserver.orgThe download link is different to the other Geoserver sites.
Any suggestions?
Brad
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Not sure I understand, the docs are generated.
The docs page, index.html, is on the web server (which has limited access). It is described in the release instructions.
On Tue, May 31, 2016 at 9:33 AM, Brad Hards <bradh@anonymised.com.4091…> wrote:
Any suggestions?
Brad
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, May 31, 2016 at 6:14 PM, Jody Garnett <jody.garnett@anonymised.com>
Oh... docs.geoserver.org... right, I believe the home page of that site is
static HTML on a Boundless
owned server (or something like that). Each version of the guide published
there is instead generated from the
rst that we have in the geoserver sources (and that Brad is already
familiar with).
Ing. Andrea Aime
@geowolf
Technical Lead
