[Geoserver-devel] Spaces in custom dimension values
I’m trying to build a mosaic using a custom domain which contains spaces.
The result in the getCapabilities is:
Cropvalue,Yield
Should be:
Crop value,Yield
I’ll provide a simple pull req for this.
Carlo
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
mobile: +39 3371094494
On Fri, Oct 11, 2013 at 6:51 PM, carlo cancellieri <
carlo.cancellieri@anonymised.com> wrote:
I'm trying to build a mosaic using a custom domain which contains spaces.
<Dimension name="MEASURE"
default="Crop value"
units="">Cropvalue,Yield</Dimension>
Should be:
units="">Crop value,Yield</Dimension>
As long as the spaces are within the value I don't foresee problems, by a
quick read of the spec,
you'd only have troubles if you have spaces at the beginning or end of the
value, where they should
be ignored (e.g., " myvalue " would be actually interpreted as "myvalue")
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Andrea,
thanks for replies.
Here is the pull req for spaces within dimensions:
https://github.com/geoserver/geoserver/pull/361
Carlo
2013/10/11 Andrea Aime <andrea.aime@anonymised.com>
On Fri, Oct 11, 2013 at 6:51 PM, carlo cancellieri <carlo.cancellieri@anonymised.com> wrote:
@cancellieric
Software Engineer
Cropvalue,Yield
Should be:
Crop value,Yield
As long as the spaces are within the value I don’t foresee problems, by a quick read of the spec,
you’d only have troubles if you have spaces at the beginning or end of the value, where they should
be ignored (e.g., " myvalue " would be actually interpreted as “myvalue”)
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Oct 15, 2013 at 11:27 AM, carlo cancellieri <
Andrea,
thanks for replies.
I believe we should still drop spaces at the begin and end of the string
using trim.
Opinions?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
using trim.
Opinions?
right, updated with trim.
Carlo
information.
@cancellieric
Software Engineer
Build stalled…
https://travis-ci.org/geoserver/geoserver/jobs/12561504
<details class='elided'>
<summary title='Show trimmed content'>&#183;&#183;&#183;</summary>
2013/10/15 carlo cancellieri <[carlo.cancellieri@anonymised.com](mailto:carlo.cancellieri@anonymised.com)>
Our support, Your Success! Visit [http://opensdi.geo-solutions.it](http://opensdi.geo-solutions.it) for more information.
@cancellieric
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it/)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Carlo
@cancellieric
Software Engineer
I believe we should still drop spaces at the begin and end of the string using trim.
Opinions?
</details>
On Tue, Oct 15, 2013 at 2:15 PM, carlo cancellieri <
Build stalled....
Eh, Travis is giving up a very nice service by building the pull requests,
but the build itself over the is not that
stable... long story short, when a build fails, it might be unrelated to
the pull request...
I'm going to try fetching and building the pull request locally.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
