[Geoserver-devel] Spatial filter for KVP GetFeature request
Hello,
I have been trying to get Geoserver 1.0.1 to work with a spatial filter and
keep on getting the following error message:
193268 [FINER] org.vfny.geoserver.requests.RequestKvpReader - clean request
is
request=GetFeature&typename=qldrstn&filter=<Filter><BBOX><PropertyName>GEOME
TRY<
/PropertyName><Box srsName="EPSG:8311"><gml:coordinates>137,-30
157,-25</gml:coo
rdinates></Box></BBOX></Filter>
193278 [FINER] org.vfny.geoserver.requests.DispatcherKvpReader - dispatcher
got
request GetFeature
193278 [FINER] org.vfny.geoserver.servlets.Dispatcher - req_type is 3
LOGGING - Got GetFeature Request
193278 [FINER] org.vfny.geoserver.requests.RequestKvpReader - clean request
is
TRY<
157,-25</gml:coo
193278 [FINER] org.geotools.filter.LogicSAXParser - made new logic factory
193278 [FINER] SubHandlerFactory - ENTRY
193278 [FINER] SubHandlerFactory - RETURN
193278 [FINER] GMLFilterDocument - ENTRY
org.geotools.gml.GMLFilterGeometry@anonymised.com
ec4
193278 [FINER] GMLFilterDocument - RETURN
193288 [FINER] GMLFilterDocument - ENTRY Filter Filter
org.xml.sax.helpers.Att
ributesImpl@anonymised.com
193288 [FINER] org.geotools.filter.FilterFilter - found start element:
Filter
193288 [FINER] GMLFilterDocument - RETURN
193288 [FINER] GMLFilterDocument - ENTRY BBOX BBOX
org.xml.sax.helpers.Attribu
193288 [FINER] org.geotools.filter.FilterFilter - found start element: BBOX
193288 [FINER] AbstractFilter - ENTRY 4
193288 [FINER] org.geotools.filter.FilterFilter - found a simple filter
start
193298 [FINER] GMLFilterDocument - RETURN
193298 [FINER] GMLFilterDocument - ENTRY PropertyName PropertyName
org.xml.sax
.helpers.AttributesImpl@anonymised.com
193298 [FINER] org.geotools.filter.FilterFilter - found start element:
Property
Name
193298 [FINER] AbstractFilter - ENTRY 101
193298 [FINER] org.geotools.filter.ExpressionSAXParser - incoming type:
Propert
yName
193298 [FINER] org.geotools.filter.ExpressionSAXParser - declared type:
null
193298 [FINER] org.geotools.filter.ExpressionSAXParser - current state:
null
193308 [FINER] org.geotools.filter.ExpressionSAXParser - is attribute
expressio
n
193308 [FINER] GMLFilterDocument - RETURN
193308 [FINER] GMLFilterDocument - ENTRY [C@anonymised.com 28 8
193308 [FINER] org.geotools.filter.ExpressionSAXParser - incoming message:
GEOM
ETRY
193308 [FINER] org.geotools.filter.ExpressionSAXParser - should read chars:
tru
e
193318 [FINER] org.geotools.filter.ExpressionSAXParser - ...
193318 [FINER] org.geotools.filter.ExpressionSAXParser - setting attribute
expr
ession: GEOMETRY
193318 [FINER] ExpressionAttribute - ENTRY GEOMETRY
193318 [FINER] GMLFilterDocument - RETURN
193318 [FINER] GMLFilterDocument - ENTRY PropertyName PropertyName
193318 [FINER] org.geotools.filter.FilterFilter - found start element:
Property
Name
193328 [FINER] AbstractFilter - ENTRY 101
193328 [FINER] org.geotools.filter.FilterFilter - found an expression
filter en
d
193328 [FINER] org.geotools.filter.ExpressionSAXParser - declared type:
Propert
yName
193328 [FINER] org.geotools.filter.ExpressionSAXParser - end message:
PropertyN
ame
193328 [FINER] org.geotools.filter.ExpressionSAXParser - current state:
complet
e
193338 [FINER] org.geotools.filter.FilterFilter - expression factory is
ready
193338 [FINER] org.geotools.filter.ExpressionSAXParser - about to create
expres
sion: GEOMETRY
193338 [FINER] org.geotools.filter.FilterSAXParser - current state (end):
right
Value
193338 [FINER] GMLFilterDocument - RETURN
193338 [FINER] GMLFilterDocument - ENTRY Box Box
org.xml.sax.helpers.Attribute
193338 [FINER] org.geotools.filter.FilterFilter - found start element: Box
193338 [FINER] AbstractFilter - ENTRY -1
193348 [FINER] GMLFilterDocument - RETURN
193348 [FINER] GMLFilterDocument - ENTRY null null gml:coordinates
org.xml.sax.
193348 [FINE] org.vfny.geoserver.responses.WfsException - >
[org.vfny.geoserver
.requests.XmlRequestReader]:
  XML getFeature request SAX parsing error: java.lang.NullPointerException
193348 [FINE] org.vfny.geoserver.responses.WfsException - return wfs
exception
is <?xml version="1.0" ?>
<ServiceExceptionReport
   version="1.2.0"
   xmlns="http://www.opengis.net/ogc&quot;
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
   xsi:schemaLocation="http://www.opengis.net/ogc
http://kimba:8081/geoserver/da
ta/capabilities/wfs/1.0.0/OGC-exception.xsd">
   <ServiceException locator="org.vfny.geoserver.requests.XmlRequestReader">
   </ServiceException>
</ServiceExceptionReport>
The URL I was trying to call was:
http://kimba:8081/geoserver/wfs?request=GetFeature&typename=qldrstn&filter=&lt;
Filter><BBOX><PropertyName>GEOMETRY</PropertyName><Box%20srsName="EPSG:8311"
<gml:coordinates>137,-30%20157,-25</gml:coordinates></Box></BBOX></Filter>
I am able to perform other non-spatial filters with no problems (the example
below works fine)
Filter><PropertyIsEqualTo><PropertyName>QLDRSTN_ID</PropertyName><Literal>6<
/Literal></PropertyIsEqualTo></Filter>
What am I doing wrong?
Thanks
Bronwyn
