while I had my head on the topic I’ve put together the following pull request (careful, it’s for discussion, not to be merged):
https://github.com/geoserver/geoserver/pull/1999
The idea is that store checks are there only to protect the capabilities document generation from exceptions, but if
we have the caps generation style configured to be tolerant to invalid layers and skip over them, then the check
is not required.
Implementation wise, catalog is loaded before the service configuration and global.xml in particular, but I’ve
added code to have a sneak peak at it before loading the catalog.
Also, GeoServerInfoImpl has been modified to default on tolerant generation if no flag is set.
What do you think, worth pursuing?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
