On Thu, Aug 13, 2015 at 12:56 AM, Torben Barsballe <
tbarsballe@anonymised.com> wrote:
How do we plan to expose the vendorOptions() for LayerGroups? Given that
they will affect how layers are displayed, they should be editable from the
GeoServer UI, but an arbitrary Map of values does not really lend itself to
a user friendly display.
Exposing these values via the REST API should also be done, but seems much
simpler.
What about creating a parallel list of scale ranges instead? Might not be
super, but
follows the current paradigm and won't break REST api backwards
compatibility.
The current structure in LayerGroupInfoImpl is:
protected List<PublishedInfo> publishables = new
ArrayList<PublishedInfo>();
protected List<StyleInfo> styles = new ArrayList<StyleInfo>();
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
