Mike Pumphrey ha scritto:
Hi Ben. I'm just getting back into doc work after a bit of an
absence, and I'm looking forward to your app-schema docs as I know
very little about it. I know that Justin has copied the skeleton of
the 1.7.x docs to trunk.
https://svn.codehaus.org/geoserver/trunk/doc/user/source/
As you can see, there's nothing there (yet). That said, if your
app-schema tutorial applies to 2.0 and not 1.7.x, I think it would
make sense to post your tutorial to trunk.
I agree it would be better. However, Ben told us trunk docs do not
build... given the option of having him figure out why or
let him temporarily commit on 1.7.x, I suggested to go the
second way, so that we can all have a look at the docs
while the situation on trunk is resolved.
It would be great if anyone knowledgeable about Sphinx could
fix whatever the problems are on trunk.
This morning I did not try out, as I'm not knowledgeable about
the build setup of sphinx. Oh well, tried just now to make a build in
doc/user and the output is:
Running Sphinx v0.6.1
loading pickled environment... not found
building [html]: targets for 1 source files that are out of date
updating environment: 1 added, 0 changed, 0 removed
reading sources... [100%] index
looking for now-outdated files... none found
pickling environment... done
checking consistency... done
preparing documents... done
writing output... [100%] index
writing additional files... search
copying static files... WARNING: static directory '/home/aaime/devel/gstrunk/doc/user/source/../../theme/_static' does not exist
done
dumping search index... done
dumping object inventory... done
build succeeded, 1 warning.
So maybe the issue is just with the theming?
The best solution would be to solve the problem enough
to have Ben commit directly on trunk without having him
stuck waiting for action from us.
Then again, the above build seems good enough to commit
the docs, at worse they will look bad? Not sure....
Andrea Aime
OpenGeo - http://opengeo.org
