[Geoserver-devel] sphinx en WinXP
Esta es la salida del comando:
This is the output of the command:
C:\prog\Python25\Scripts>easy_install sphinx
Searching for sphinx
Reading http://pypi.python.org/simple/sphinx/
Download error: (11001, ‘getaddrinfo failed’) – Some packages may not be found!
Couldn’t find index page for ‘sphinx’ (maybe misspelled?)
Scanning index of all packages (this may take a while)
No locate packages or download links found for sphinx
error: Could not find suitable distribution for Requirement.parse(‘sphinx’)
www.nramire1.unlugar.com
— El lun 3-ago-09, Mike Pumphrey mike@anonymised.com escribió:
> De: Mike Pumphrey mike@anonymised.com
> Asunto: Re: [Fwd: Re: [Geoserver-devel] Talking multilingual documentation framework blues]
> Para: “nramire1” nramire1@anonymised.com
> Fecha: lunes, 3 de agosto de 2009, 3:52 pm
> Hi. You should add the following directory to your PATH environment variable:
> Or, you can go into that directory and run “easy_install sphinx” there, as that is where the easy_install program is located.
> Hope this helps…
> Thanks,
> Mike Pumphrey
> OpenGeo - http://opengeo.org
> nramire1 wrote:
> > seguí el instructivo: http://docs.geoserver.org/trunk/en/docguide/install.html
> > 1 descargue el instalador de python 2,5 2 descargue el instalador de setuptools for Python 2.5 3 instale: python instale: setuptools for Python 2.5 agrego las variables de entorno winxp:
> > variable de sistema: nueva
> > nombre variable: PYTHON
> > valor variable: C:\prog\Python25;C:\prog\Python25\Scripts
> > 4 cuando quiero correr en comando
> > c:>easy_install sphinx
> > “easy_install” no se reconoce como un comando interno o externo.
> > Lo he revisado varias veces, pero no encuentro que esta mal.
> > I followed the instructions: http://docs.geoserver.org/trunk/en/docguide/install.html
> > 1 download the installer for python 2.5 2 download the setuptools installer for Python 2.5 3 install: python (C:\prog)
> > install: setuptools for Python 2.5 (C:\prog\Python25)
> > add winxp environment variables: system variable: new variable name: PYTHON variable value: C:\prog\Python25, C:\prog\Python25\Scripts
> > 4 when I run command c: > easy_install sphinx “Easy_install” is not recognized as an internal or external command.
> > I have revised several times but did not find that bad.
Encontra las mejores recetas con Yahoo! Cocina.
http://ar.mujer.yahoo.com/cocina/
Some other people have had trouble easy_install'ing sphinx as well. Youc an try a manual install:
Go to:
http://pypi.python.org/pypi/Jinja
http://pypi.python.org/pypi/Sphinx
Download the packages, unpack and run setup.py.
Hope that helps.
-Justin
Download error: (11001, 'getaddrinfo failed') -- Some packages may not be found!
Couldn't find index page for 'sphinx' (maybe misspelled?)
error: Could not find suitable distribution for Requirement.parse('sphinx')
www.nramire1.unlugar.com <http://www.nramire1.unlugar.com/&gt;
--- El *lun 3-ago-09, Mike Pumphrey /<mike@anonymised.com>/* escribió:
    De: Mike Pumphrey <mike@anonymised.com>
    Para: "nramire1" <nramire1@anonymised.com>
    variable:
    Or, you can go into that directory and run "easy_install sphinx"
    Hope this helps...
    Mike Pumphrey
    nramire1 wrote:
     > seguí el instructivo:
     > 1 descargue el instalador de python 2,5 2 descargue el instalador
     > variable de sistema: nueva
     > nombre variable: PYTHON
     > valor variable: C:\prog\Python25;C:\prog\Python25\Scripts
     > 4 cuando quiero correr en comando
     > c:\>easy_install sphinx
     > “easy_install” no se reconoce como un comando interno o externo.
     > Lo he revisado varias veces, pero no encuentro que esta mal.
     > I followed the instructions:
     > 1 download the installer for python 2.5 2 download the setuptools
    installer for Python 2.5 3 install: python (C:\prog\)
     > install: setuptools for Python 2.5 (C:\prog\Python25\)
     > add winxp environment variables: system variable: new variable
     > 4 when I run command c: \> easy_install sphinx "Easy_install" is
     > I have revised several times but did not find that bad.
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-devel mailing list
Justin Deoliveira
Hmm, not sure about that. Googling that error yields talk about network/proxy issues on your side. Can you browse to http://pypi.python.org/simple/sphinx/ ?
Anyone else seen these types of issues?
You may have to download/install Sphinx manually, but I don't know much about that, I confess.
Mike Pumphrey
    variable:
    Hope this helps...
    Mike Pumphrey
