Hello,
I have checked out the trunk user doco OK …
svn checkout http://svn.codehaus.org/geoserver/trunk/doc/en/user
A generated the pickle files, also …
make pickle
But I get this when I try to generate HTML from the .rst files …
C:\Geo_Doc\user>make html
Running Sphinx v1.0.7
loading pickled environment… done
Theme error:
no theme named ‘geoserver’ found (missing theme.conf?)
Build finished. The HTML pages are in build/html.
(I also got this error in Ubuntu.)
There are no files in build\html after this.
David
Hi David. If you checkout the directory above:
svn checkout https://svn.codehaus.org/geoserver/trunk/doc/en/
You'll pull in the themes directory, which is:
https://svn.codehaus.org/geoserver/trunk/doc/en/themes/
Mike Pumphrey
OpenGeo - http://opengeo.org
On 1/20/2011 3:24 PM, David Collins wrote:
Hello,
I have checked out the trunk user doco OK ..
A generated the pickle files, also ..
make pickle
But I get this when I try to generate HTML from the .rst files ..
loading pickled environment... done
*Theme error:
no theme named 'geoserver' found (missing theme.conf?)
David
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
Geoserver-devel mailing list
Thanks - good now.
You’ll pull in the themes directory, which is:
Mike Pumphrey
Hello,
make pickle
*Theme error:
David
