[Geoserver-devel] Sphinx version
working on fixing minor documentation issues, I added an excluded_patterns variable to Sphinx’s configuration file, conf.py.
The docs say this variable was introduced in version 1.0, so I wondered: what Sphinx version is the build server running? Does anybody know?
Thanks in advance!
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
55054  Massarosa (LU)
fax:     +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
The answer to your questions is in the build logs, e.g., taking:
http://ares.boundlessgeo.com/jenkins/view/geoserver/job/geoserver-master/1926/consoleText
and searching for sphinx, gives us:
sphinx-build -b html -d build/doctrees source build/html
Running Sphinx v1.2b1
loading pickled environment… not yet created
building [html]: targets for 442 source files that are out of date
updating environment: 442 added, 0 changed, 0 removed
reading sources… [ 0%] advanced/crshandling/configurecrs
reading sources… [ 0%] advanced/crshandling/coordtransforms
reading sources… [ 0%] advanced/crshandling/customcrs
On Thu, Oct 29, 2015 at 11:09 AM, Stefano Costa <stefano.costa@anonymised.com> wrote:
Thanks in advance!
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Ah! Thanks for the hint.
I guess I will go on adding the variable, then.
On Thu, Oct 29, 2015 at 11:16 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Oct 29, 2015 at 11:09 AM, Stefano Costa <stefano.costa@anonymised.com…1268…> wrote:
Thanks in advance!
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Ing. Andrea Aime
@geowolf
Technical Lead
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
I found a better way to fix the issue I was after, which does not involve introducing a excluded_patterns variable…
Anyway, good to know that’s an option, in case of future needs :wink:
On Thu, Oct 29, 2015 at 11:19 AM, Stefano Costa <stefano.costa@anonymised.com> wrote:
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Thanks in advance!
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Ing. Andrea Aime
@geowolf
Technical Lead
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Version 1.3.1 is now available https://pypi.python.org/pypi/Sphinx which might be worth considering while we are upgrading things
Ian
On 29 October 2015 at 10:55, Stefano Costa <stefano.costa@anonymised.com> wrote:
On Thu, Oct 29, 2015 at 11:19 AM, Stefano Costa <stefano.costa@anonymised.com68…> wrote:
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Thanks in advance!
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
