As an FYI relating to GEOS-1831, i managed to get GeoServer trunk up and running in Spring 2.5.2. I have not done any rigorous testing, but hitting the UI, some basic get capabilities cals, and the map preview seem to work ok.
I also tried the Acegi stuff and it seems to work fine. I was able to set up a role for a service, secure it, and final authenticate to access it.
It required changing some of the dependencies on spring around, as they have moved classes around into new modules in 2.5. But it seems to work ok.
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
