Do not worry about login/logout for GeoExplorer.
However I think the endpoint may be used by others so we should supply migration instructions for anyone else affected.
Jody Garnett
On 3 March 2016 at 23:24, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi all
I think it is necessary to upgrade, +1 here. I have seen Justin created a branch spring4-upgrade fixing the broken security code.
For CAS I have an online test scenario.
On Thu, Mar 3, 2016 at 6:19 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks Simone, updating the page. I will give Christian another day and then I would like to start making plans.
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Jody Garnett
On 3 March 2016 at 09:16, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Jody,
I am for upgrading to Spring 4 + delaying the release.I already told Andrea we can devote resources to help with the upgrade.
Simone GiannecchiniGeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.Ing. Simone Giannecchini
@simogeo
Founder/DirectorGeoSolutions S.A.S.
Via di Montramito 3/A
mob: +39 333 8128928http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.On Thu, Mar 3, 2016 at 6:04 PM, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Thanks Brad, updated the table accordingly. I probably should of phrased
this as a yes/no question.We are waiting on two PSC members:
- Christian Mueller
- Simone Giannecchini
Jody GarnettOn 3 March 2016 at 06:18, Brad Hards <bradh@anonymised.com> wrote:
On Thu, 3 Mar 2016 06:08:39 PM Ben Caradoc-Davies wrote:
Thank you so much Jody for all your work rounding this up.
I am +1 to delay the release and upgrade now to Spring 4.
I’m OK with either solution (with a very slight preference for keeping a
Java
8 solution). Happy for those who understand the implications (in
particular,
the risks and work involved) at a deeper level to make the call on this.Brad
