If we shall get the new “Open J Imaging” system this year, how much will it break and will it still fit into the 3.x series?
-Jukka Rahkonen-
Andrea Aime wrote:
If we follow the tradition set for GeoServer 2.x, we should be switch to 3.0
once the JDBCConfig module is ready to become core and act as the
replacement for the data directory.
On Thu, Mar 3, 2016 at 6:08 AM, Ben Caradoc-Davies <ben@…4191…> wrote:
Thank you so much Jody for all your work rounding this up.
I am +1 to delay the release and upgrade now to Spring 4.
Support for Java 8 for both users and developers is one of the major
selling points for the 2.9 release. I think it is worthwhile to clear
this technical debt so that we can deliver full support for Java 8.If we get this out the door in the next month or so, we could even
consider it a 3.0 release, as we have big changes with both Wicket 7 and
Java 8. Or would that be GeoTools 9.0 (dropping major version in the
tradition of Solaris and GeoTools)?Kind regards,
Ben.On 01/03/16 21:42, Jody Garnett wrote:
I have gathered up email, notes and conversations here:
We will be upgrading (one way or another) to Spring 4 shortly.
I would like to ask the PSC to review the above, add to it with your own
research, and make a decision about:
- Temp Fix: Build and Run with Java 8 carefully
- Upgrade Now: Delay Release and Migrate to Spring 4
We have a couple of outstanding questions, most noticeably contacting
Christian with respect to the Security CAS module.
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
