Hmm,
I'm not sure if commons-pool 2.0 will affect ArcSDE. I'll give it a shot today and see if it breaks anything.
--saul
From: geoserver-devel-bounces@lists.sourceforge.net on behalf of Gabriel Roldán
Sent: Wed 6/13/2007 10:01 AM
To: geoserver-devel@lists.sourceforge.net; Farber, Saul (ENV)
Cc: Jody Garnett
Subject: Re: [Geoserver-devel] spring dependency and commons pool
Hi Jody,
using commons-pool 2.0 seems right, and thanks for chiming on the list before
adding the dependency as it will affect the arcsde plugin too.
I had problems with mixed library versions between modules before, so it'll be
great to coordinate and make sure a single one is used across modules and
even more, across projects ( in this case, geotools<-->geoserver)
Saul, do you foresee any problem for arcsde moving to commons-pool 2.0?
cheers,
Gabriel
On Tuesday 12 June 2007 01:18:50 Jody Garnett wrote:
Hi Andrea?
I was about to add a dependency on commons-pool to referencing (so we
can toss out some of our faux datasource stuff). I was going to try and
grab the latest - in version 2 they have factored out there classes into:
- class heirarchy for type off pool (strong reference, weak reference
etc...)
- strategy object for policy (FIFO, LIFO, etc...)
Basically they have half the number of classes.
But I noticed that spring depends on commons-pool 1.3 - and I don't
really want to see both things tripping over each other for geoserver?
What are your thoughts?
Jody
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-devel mailing list
