I’m relatively new to building geoserver from source so I’m not comfortable filing a bug until I make sure I’m not making basic mistakes myself. In particular David Winslow helped me today by correcting some errors in the build for the RESTConfig and rest community modules. I svn up’d, did a mvn clean and finally a mvn install -Dcommunity -P RESTConfig,rest
When I deployed the war to tomcat I get a bunch of Spring configuration errors (which I pasted in below.) I’m familiar with Spring but because I’m just getting to know the code I thought someone might see something obvious to them that would take me awhile to track down.
INFO: Deploying web application archive geoserver.war
Jun 14, 2008 12:07:42 AM org.apache.catalina.core.StandardContext addApplicationListener
INFO: The listener “org.geoserver.GeoserverInitStartupListener” is already configured for this context. The duplicate definition has been ignored.
INFO: The listener “org.geoserver.logging.LoggingStartupContextListener” is already configured for this context. The duplicate definition has been ignored.
INFO: The listener “org.springframework.web.context.ContextLoaderListener” is already configured for this context. The duplicate definition has been ignored.
14 Jun 00:07:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: C:\cygwin\opt\apache-tomcat-6.0.16\webapps\geoserver\data
14 Jun 00:07:44 INFO [geoserver.catalog] - Loaded namespace ‘it.geosolutions’ (http://www.geo-solutions.it)
14 Jun 00:07:44 INFO [geoserver.catalog] - Loaded namespace ‘topp’ (http://www.openplans.org/topp)
14 Jun 00:07:44 INFO [geoserver.catalog] - Default namespace: ‘topp’
14 Jun 00:07:44 INFO [geoserver.catalog] - Loaded style ‘polygon’
14 Jun 00:07:44 INFO [geoserver.catalog] - Loaded style ‘raster’
14 Jun 00:07:44 INFO [geoserver.catalog] - Loaded style ‘point’
14 Jun 00:07:44 INFO [geoserver.catalog] - Loaded style ‘line’
14 Jun 00:07:44 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.Be
anCreationNotAllowedException: Error creating bean with name ‘wcsLoader’: Singleton bean creation not allowed while the singletons of this factory are in destructio
n (Do not request a bean from a BeanFactory in a destroy method implementation!)
14 Jun 00:07:44 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘applicationState’ defined in URL [file:/C:/cygwin/opt/apache-tomcat-6.0.16/w
ebapps/geoserver/WEB-INF/classes/applicationContext.xml]: Cannot resolve reference to bean ‘data’ while setting constructor argument; nested exception is org.spring
framework.beans.factory.BeanCreationException: Error creating bean with name ‘data’ defined in URL [jar:file:/C:/cygwin/opt/apache-tomcat-6.0.16/webapps/geoserver/W
EB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘geoServer2’ while setting constructor argument; nested exception is o
rg.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer2’ defined in URL [jar:file:/C:/cygwin/opt/apache-tomcat-6.0.16/weba
pps/geoserver/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang
.NullPointerException
Related cause: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘secureCatalog’ defined in URL [jar:file:/C:/cygwin/o
pt/apache-tomcat-6.0.16/webapps/geoserver/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Unsatisfied dependency expressed through constructor argumen
t with index 1 of type [org.geoserver.security.DataAccessManager]: Ambiguous constructor argument types - did you specify the correct bean references as constructor
arguments?
arguments?
arguments?
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:474)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:160)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:893)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:803)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:437)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:404)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:375)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:263)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:170)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:260)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:184)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:163)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:430)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:254)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:198)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3843)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4350)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:525)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:829)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:718)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:490)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1147)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:578)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘data’ defined in URL [jar:file:/C:/cygwin/opt/apache-tomcat-6.0.1
6/webapps/geoserver/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘geoServer2’ while setting constructor argument;
nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer2’ defined in URL [jar:file:/C:/cygwin/opt/apac
he-tomcat-6.0.16/webapps/geoserver/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.Runtim
eException: java.lang.NullPointerException
arguments?
arguments?
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
… 44 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer2’ defined in URL [jar:file:/C:/cygwin/opt/apache-tomcat
-6.0.16/webapps/geoserver/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeExceptio
arguments?
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:470)
… 59 more
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:87)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:67)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFacto
ry.java:346)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1295)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:463)
… 68 more
Caused by: java.lang.NullPointerException
at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:137)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:84)
… 72 more
Related cause:
org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘secureCatalog’ defined in URL [jar:file:/C:/cygwin/opt/apache-tomca
t-6.0.16/webapps/geoserver/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Unsatisfied dependency expressed through constructor argument with index 1
of type [org.geoserver.security.DataAccessManager]: Ambiguous constructor argument types - did you specify the correct bean references as constructor arguments?
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:556)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:190)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1210)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:978)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:462)
Jun 14, 2008 12:07:44 AM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/geoserver] startup failed due to previous errors
Christopher Thatcher
