[Geoserver-devel] spring framework problem
Hey list!
I'm trying to run geoserver from JDeveloper. It compiled ok, but running it
is a different story. I get the following exception:
2007.1.11 14:52:21 org.springframework.web.context.ContextLoader
initWebApplicationContext
INFO: Root WebApplicationContext: initialization started
SEVERE: Context initialization failed
org.springframework.beans.factory.BeanDefinitionStoreException: Could not
resolve bean definition resource pattern
[classpath*:/applicationContext.xml]; nested exception is
java.net.MalformedURLException: unknown protocol: jndi
  at java.net.URL.<init>(URL.java:544)
  at java.net.URL.<init>(URL.java)
  at org.springframework.core.io.UrlResource.<init>(UrlResource.java:57)
any idea where the problem might be?
View this message in context: http://www.nabble.com/spring-framework-problem-tf2958988.html#a8277834
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
GeoUser ha scritto:
Hey list!
Are you sure JDeveloper includes the applicationContext.xml files in
the classpath? Maybe that as simple as that, the IDE not treating
those as resources and not copying them along with the .class files.
Oh, if you succeed, can you provide us with a set of steps to setup
the developer environment with JDeveloper? It's not the first time
I hear such a request, but no one among us uses it.
We are already working with Geoserver 1.3.4 that was ported to JDeveloper.
It's working nicely, no problem debugging it, simple to run from IDE
(oc4j).... When Geoserver 1.5.x starts working i'll write down the steps and
copy&paste them here.
Andrea Aime-3 wrote:
GeoUser ha scritto:
Hey list!
it
not
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-devel mailing list
View this message in context: http://www.nabble.com/spring-framework-problem-tf2958988.html#a8296688
well i got it working to some degree, geoserver almost starts under
jdeveloper :slight_smile: almost
this is the startup log:
07/01/15 13:20:56 Oracle Containers for J2EE 10g (10.1.3.1.0) initialized
15.1.2007 13:20:59 org.springframework.web.context.ContextLoader
15.1.2007 13:21:00
org.springframework.beans.factory.xml.XmlBeanDefinitionReader
loadBeanDefinitions
INFO: Loading XML bean definitions from URL
[file:/E:/programs/jdeveloper1013/jdev/mywork/Geoserver
1.5.x/Geoserver/public_html/WEB-INF/classes/applicationContext.xml]
15.1.2007 13:21:00
loadBeanDefinitions
[code-source:/E:/programs/jdeveloper1013/jdev/mywork/Geoserver
1.5.x/Geoserver/public_html/WEB-INF/lib/wms-1.5.0-beta1.jar!/applicationContext.xml]
15.1.2007 13:21:00
loadBeanDefinitions
1.5.x/Geoserver/public_html/WEB-INF/lib/data-1.5.0-beta1.jar!/applicationContext.xml]
15.1.2007 13:21:00
loadBeanDefinitions
1.5.x/Geoserver/public_html/WEB-INF/lib/validation-1.5.0-beta1.jar!/applicationContext.xml]
15.1.2007 13:21:00
loadBeanDefinitions
1.5.x/Geoserver/public_html/WEB-INF/lib/wcs-1.5.0-beta1.jar!/applicationContext.xml]
15.1.2007 13:21:00
loadBeanDefinitions
1.5.x/Geoserver/public_html/WEB-INF/lib/main-1.5.0-beta1.jar!/applicationContext.xml]
15.1.2007 13:21:00
loadBeanDefinitions
1.5.x/Geoserver/public_html/WEB-INF/lib/wfs-1.5.0-beta1.jar!/applicationContext.xml]
15.1.2007 13:21:00
org.springframework.context.support.AbstractRefreshableApplicationContext
refreshBeanFactory
INFO: Bean factory for application context [Root WebApplicationContext]:
org.springframework.beans.factory.support.DefaultListableBeanFactory
defining beans
[applicationState,applicationStateRegisterar,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,catalog,serviceFinder,validation,validationConfig,validationRegisterar,validationConfigRegisterar,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction];
root of BeanFactory hierarchy
15.1.2007 13:21:00
org.springframework.context.support.AbstractApplicationContext refresh
INFO: 68 beans defined in application context [Root WebApplicationContext]
15.1.2007 13:21:00 org.springframework.core.CollectionFactory <clinit>
INFO: JDK 1.4+ collections available
15.1.2007 13:21:00
initMessageSource
INFO: Unable to locate MessageSource with name 'messageSource': using
default
[org.springframework.context.support.DelegatingMessageSource@anonymised.com]
15.1.2007 13:21:00
initApplicationEventMulticaster
INFO: Unable to locate ApplicationEventMulticaster with name
'applicationEventMulticaster': using default
[org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com029...]
15.1.2007 13:21:00
org.springframework.ui.context.support.UiApplicationContextUtils
initThemeSource
INFO: Unable to locate ThemeSource with name 'themeSource': using default
[org.springframework.ui.context.support.ResourceBundleThemeSource@anonymised.com...]
15.1.2007 13:21:00
preInstantiateSingletons
INFO: Pre-instantiating singletons in factory
[org.springframework.beans.factory.support.DefaultListableBeanFactory
defining beans
root of BeanFactory hierarchy]
07/01/15 13:21:00 ----------------------------------
07/01/15 13:21:00 - GEOSERVER_DATA_DIR:
E:\programs\jdeveloper1013\jdev\mywork\Geoserver
1.5.x\Geoserver\public_html
0 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - logging level
is CONFIG
0 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - maxFeatures is
1000000
16 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - numDecimals
returning is 8
16 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - charSet is
UTF-8
16 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - reading
srsXmlStyle: oracle.xml.parser.v2.XMLElement@anonymised.com
16 [INFO] org.vfny.geoserver.global.xml.XMLConfigReader - No baseMap
groups defined yet
16 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configuration file: E:\programs\jdeveloper1013\jdev\mywork\Geoserver
1.5.x\Geoserver\public_html\WEB-INF\catalog.xml
32 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xmlns:topp="http://www.openplans.org/topp&quot;, isDefault=true
namespace xmlns:sde="http://geoserver.sf.net", isDefault=false
namespace xmlns:nurc="http://www.nurc.nato.int", isDefault=false
namespace xmlns:tiger="http://www.census.gov", isDefault=false
namespace xmlns:cite="http://www.opengeospatial.net/cite&quot;, isDefault=false
47 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore DS_giant_polygon
datastore states_shapefile
datastore DS_poi
datastore tasmania_cities
datastore tasmania_roads
datastore tasmania_state_boundaries
datastore DS_poly_landmarks
141 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore DS_tiger_roads
datastore tasmania_water_bodies
157 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
giant_polygon
capitals
tiger_roads
poly_landmarks
green
simple_roads
dem
population
line
raster
polygon
point
poi
cite_lakes
157 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
1.5.x\Geoserver\public_html\data\featureTypes\DS_giant_polygon_giant_polygon\info.xml
282 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType giant_polygon
297 [INFO] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
297 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
1.5.x\Geoserver\public_html\data\featureTypes\DS_poi_poi\info.xml
297 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType poi
1.5.x\Geoserver\public_html\data\featureTypes\DS_poly_landmarks_poly_landmarks\info.xml
featureType poly_landmarks
1.5.x\Geoserver\public_html\data\featureTypes\DS_tiger_roads_tiger_roads\info.xml
featureType tiger_roads
1.5.x\Geoserver\public_html\data\featureTypes\states\info.xml
featureType states
1.5.x\Geoserver\public_html\data\featureTypes\tasmania_cities\info.xml
featureType tasmania_cities
407 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
1.5.x\Geoserver\public_html\data\featureTypes\tasmania_roads\info.xml
407 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType tasmania_roads
407 [INFO] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
1.5.x\Geoserver\public_html\data\featureTypes\tasmania_state_boundaries\info.xml
featureType tasmania_state_boundaries
1.5.x\Geoserver\public_html\data\featureTypes\tasmania_water_bodies\info.xml
featureType tasmania_water_bodies
500 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category CRSFactory:
  org.geotools.referencing.factory.GeotoolsFactory
641 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category DatumFactory:
  org.geotools.referencing.factory.DatumAliases
implementations for category MathTransformFactory:
  org.geotools.referencing.operation.DefaultMathTransformFactory
844 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category GridFormatFactorySpi:
  org.geotools.gce.arcgrid.ArcGridFormatFactory
  org.geotools.gce.geotiff.GeoTiffFormatFactorySpi
  org.geotools.gce.gtopo30.GTopo30FormatFactory
  org.geotools.gce.image.WorldImageFormatFactory
  org.geotools.gce.imagemosaic.ImageMosaicFormatFactory
  org.geotools.gce.imagepyramid.ImagePyramidFormatFactory
2157 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category GridCoverageFactory:
  org.geotools.coverage.grid.GridCoverageFactory
2188 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category CoordinateOperationFactory:
  org.geotools.referencing.operation.DefaultCoordinateOperationFactory
  org.geotools.referencing.operation.AuthorityBackedFactory
  org.geotools.referencing.operation.BufferedCoordinateOperationFactory
implementations for category CSFactory:
2204 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category CoordinateOperationAuthorityFactory:
  org.geotools.referencing.factory.epsg.DefaultFactory
2219 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category DataSource:
  org.geotools.referencing.factory.epsg.HSQLDataSource
2875 [INFO] - Created a "jdbc/EPSG" entry in the naming system.
2875 [CONFIG] - Connected to EPSG database
"jdbc:hsqldb:file:/C:/DOCUME~1/xp/LOCALS~1/Temp/Geotools/Databases/HSQL/EPSG"
on "HSQL Database Engine".
2938 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category CRSAuthorityFactory:
  org.geotools.referencing.factory.epsg.LongitudeFirstFactory
  org.geotools.referencing.factory.wms.AutoCRSFactory
  org.geotools.referencing.factory.wms.WebCRSFactory
3532 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for category MathTransformProvider:
org.geotools.referencing.operation.transform.LogarithmicTransform1D$Provider
org.geotools.referencing.operation.transform.ExponentialTransform1D$Provider
org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderAffine
org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderLongitudeRotation
org.geotools.referencing.operation.transform.GeocentricTranslation$Provider
org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderSevenParam
org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderFrameRotation
org.geotools.referencing.operation.transform.GeocentricTransform$Provider
org.geotools.referencing.operation.transform.GeocentricTransform$ProviderInverse
org.geotools.referencing.operation.transform.MolodenskiTransform$Provider
org.geotools.referencing.operation.transform.MolodenskiTransform$ProviderAbridged
  org.geotools.referencing.operation.transform.NADCONTransform$Provider
  org.geotools.referencing.operation.transform.WarpTransform2D$Provider
org.geotools.referencing.operation.projection.EquidistantCylindrical$Provider
  org.geotools.referencing.operation.projection.PlateCarree$Provider
  org.geotools.referencing.operation.projection.Mercator1SP$Provider
  org.geotools.referencing.operation.projection.Mercator2SP$Provider
org.geotools.referencing.operation.projection.TransverseMercator$Provider
org.geotools.referencing.operation.projection.TransverseMercator$Provider_SouthOrientated
  org.geotools.referencing.operation.projection.ObliqueMercator$Provider
org.geotools.referencing.operation.projection.ObliqueMercator$Provider_Hotine
org.geotools.referencing.operation.projection.ObliqueMercator$Provider_TwoPoint
org.geotools.referencing.operation.projection.ObliqueMercator$Provider_Hotine_TwoPoint
  org.geotools.referencing.operation.projection.AlbersEqualArea$Provider
org.geotools.referencing.operation.projection.LambertConformal1SP$Provider
org.geotools.referencing.operation.projection.LambertConformal2SP$Provider
org.geotools.referencing.operation.projection.LambertConformalBelgium$Provider
org.geotools.referencing.operation.projection.LambertConformalESRI$Provider
  org.geotools.referencing.operation.projection.Orthographic$Provider
org.geotools.referencing.operation.projection.Stereographic$Provider_Oblique
org.geotools.referencing.operation.projection.Stereographic$Provider_Polar_A
org.geotools.referencing.operation.projection.Stereographic$Provider_Polar_B
org.geotools.referencing.operation.projection.Stereographic$Provider_North_Pole
org.geotools.referencing.operation.projection.Stereographic$Provider_South_Pole
org.geotools.referencing.operation.projection.Stereographic$Provider_USGS
  org.geotools.referencing.operation.projection.NewZealandMapGrid$Provider
  org.geotools.referencing.operation.projection.Krovak$Provider
15.1.2007 13:21:04
org.springframework.beans.factory.support.AbstractBeanFactory
destroySingletons
INFO: Destroying singletons in factory
{org.springframework.beans.factory.support.DefaultListableBeanFactory
defining beans
root of BeanFactory hierarchy}
15.1.2007 13:21:04 org.springframework.web.context.ContextLoader
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'applicationState' defined in URL
1.5.x/Geoserver/public_html/WEB-INF/classes/applicationContext.xml]: Can't
resolve reference to bean 'data' while setting property 'constructor
argument'; nested exception is
bean with name 'data' defined in URL
1.5.x/Geoserver/public_html/WEB-INF/lib/main-1.5.0-beta1.jar!/applicationContext.xml]:
Can't resolve reference to bean 'geoServer' while setting property
'constructor argument'; nested exception is
bean with name 'geoServer' defined in URL
Instantiation of bean failed; nested exception is
org.springframework.beans.FatalBeanException: Could not instantiate class
[org.vfny.geoserver.global.GeoServer]; constructor threw exception; nested
exception is java.lang.ExceptionInInitializerError: null
  at org.vfny.geoserver.global.GeoServer.initJAI(GeoServer.java:586)
  at org.vfny.geoserver.global.GeoServer.load(GeoServer.java:440)
  at org.vfny.geoserver.global.GeoServer.<init>(GeoServer.java:108)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
  at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
  at
org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
  at
org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:75)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:669)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:329)
  at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
  at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
  at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:176)
  at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:105)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.resolveConstructorArguments(AbstractAutowireCapableBeanFactory.java:713)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:611)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:275)
  at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:318)
  at
org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
  at
org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
  at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
  at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
  at
com.evermind.server.http.HttpApplication.initDynamic(HttpApplication.java:1130)
  at
com.evermind.server.http.HttpApplication.<init>(HttpApplication.java:738)
  at
com.evermind.server.ApplicationStateRunning.getHttpApplication(ApplicationStateRunning.java:414)
  at
com.evermind.server.Application.getHttpApplication(Application.java:545)
  at
com.evermind.server.http.HttpSite$HttpApplicationRunTimeReference.createHttpApplicationFromReference(HttpSite.java:1990)
  at
com.evermind.server.http.HttpSite$HttpApplicationRunTimeReference.createHttpApplicationFromReference(HttpSite.java:1973)
  at
com.evermind.server.http.HttpSite$HttpApplicationRunTimeReference.getHttpApplication(HttpSite.java:1925)
  at com.evermind.server.http.HttpSite.getApplication(HttpSite.java:424)
  at
com.evermind.server.http.HttpRequestHandler.resolveApplication(HttpRequestHandler.java:393)
  at
com.evermind.server.http.HttpRequestHandler.processRequest(HttpRequestHandler.java:434)
  at
com.evermind.server.http.HttpRequestHandler.serveOneRequest(HttpRequestHandler.java:216)
  at
com.evermind.server.http.HttpRequestHandler.run(HttpRequestHandler.java:117)
  at
com.evermind.server.http.HttpRequestHandler.run(HttpRequestHandler.java:110)
  at
oracle.oc4j.network.ServerSocketReadHandler$SafeRunnable.run(ServerSocketReadHandler.java:260)
  at
oracle.oc4j.network.ServerSocketAcceptHandler.procClientSocket(ServerSocketAcceptHandler.java:239)
  at
oracle.oc4j.network.ServerSocketAcceptHandler.access$700(ServerSocketAcceptHandler.java:34)
  at
oracle.oc4j.network.ServerSocketAcceptHandler$AcceptHandlerHorse.run(ServerSocketAcceptHandler.java:880)
  at
com.evermind.util.ReleasableResourcePooledExecutor$MyWorker.run(ReleasableResourcePooledExecutor.java:298)
  at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.NullPointerException
  at
com.sun.media.imageioimpl.common.ImageUtil.getJDKImageReaderWriterSPI(ImageUtil.java:1366)
  at
com.sun.media.imageioimpl.common.ImageUtil.processOnRegistration(ImageUtil.java:1414)
  at
com.sun.media.imageioimpl.plugins.wbmp.WBMPImageReaderSpi.onRegistration(WBMPImageReaderSpi.java:95)
  at
javax.imageio.spi.SubRegistry.registerServiceProvider(ServiceRegistry.java:698)
  at
javax.imageio.spi.ServiceRegistry.registerServiceProvider(ServiceRegistry.java:285)
  at
javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:183)
  at javax.imageio.spi.IIORegistry.<init>(IIORegistry.java:117)
  at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:138)
  at javax.imageio.ImageIO.<clinit>(ImageIO.java:46)
  ... 52 more
seems to have problems with beans?
any ideas?
View this message in context: http://www.nabble.com/spring-framework-problem-tf2958988.html#a8370777
any ideas?
I bet a beer that you're missing JAI in your classpath?
Either you haven't installed it in your JRE or you haven't put the
pure java jai and jai image i/o jars in the classpath?
Geoserver 1.5 requires JAI for both WMS and WCS, basically cannot
start without it.
It seems that it cannot initialize JAI … can you check your installation, and in particoular the native libraries, and your classpath? Try even to completely remove the native libs.
15.1.2007 13:21:00
loadBeanDefinitions
15.1.2007 13:21:00
loadBeanDefinitions
15.1.2007 13:21:00
loadBeanDefinitions
1.5.x/Geoserver/public_html/WEB-INF/lib/data-1.5.0-beta1.jar!/applicationContext.xml ]
15.1.2007 13:21:00
loadBeanDefinitions
15.1.2007 13:21:00
loadBeanDefinitions
15.1.2007 13:21:00
loadBeanDefinitions
15.1.2007 13:21:00
loadBeanDefinitions
15.1.2007 13:21:00
refreshBeanFactory
defining beans
15.1.2007 13:21:00
15.1.2007 13:21:00
initMessageSource
INFO: Unable to locate MessageSource with name ‘messageSource’: using
default
15.1.2007 13:21:00
‘applicationEventMulticaster’: using default
[org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com]
15.1.2007 13:21:00
initThemeSource
INFO: Unable to locate ThemeSource with name ‘themeSource’: using default
[org.springframework.ui.context.support.ResourceBundleThemeSource@anonymised.com ]
15.1.2007 13:21:00
defining beans
is CONFIG
1000000
returning is 8
UTF-8
groups defined yet
namespace xmlns:topp=“http://www.openplans.org/topp”, isDefault=true
namespace xmlns:sde=" http://geoserver.sf.net", isDefault=false
namespace xmlns:nurc=" http://www.nurc.nato.int", isDefault=false
namespace xmlns:tiger=“http://www.census.gov”, isDefault=false
namespace xmlns:cite=“http://www.opengeospatial.net/cite”, isDefault=false
datastore DS_poi
giant_polygon
capitals
tiger_roads
poly_landmarks
green
simple_roads
dem
population
line
raster
polygon
point
poi
cite_lakes
featureType poi
featureType states
2875 [INFO] - Created a “jdbc/EPSG” entry in the naming system.
“jdbc:hsqldb:file:/C:/DOCUME~1/xp/LOCALS~1/Temp/Geotools/Databases/HSQL/EPSG”
on “HSQL Database Engine”.
15.1.2007 13:21:04
destroySingletons
defining beans
bean with name ‘applicationState’ defined in URL
1.5.x/Geoserver/public_html/WEB-INF/classes/applicationContext.xml]: Can’t
resolve reference to bean ‘data’ while setting property ‘constructor
argument’; nested exception is
bean with name ‘data’ defined in URL
Can’t resolve reference to bean ‘geoServer’ while setting property
‘constructor argument’; nested exception is
bean with name ‘geoServer’ defined in URL
1.5.x /Geoserver/public_html/WEB-INF/lib/main-1.5.0-beta1.jar!/applicationContext.xml]:
1.5.x/Geoserver/public_html/WEB-INF/lib/main-1.5.0-beta1.jar!/applicationContext.xml ]:
at org.vfny.geoserver.global.GeoServer.initJAI (GeoServer.java:586)
at org.vfny.geoserver.global.GeoServer.(GeoServer.java:108)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0 (Native Method)
at
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java :27)
at
at
org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate (SimpleInstantiationStrategy.java:75)
at
at
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean (AbstractBeanFactory.java:226)
at
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference (BeanDefinitionValueResolver.java:176)
at
at
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor (AbstractAutowireCapableBeanFactory.java:611)
at
at
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java :147)
at
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary (BeanDefinitionValueResolver.java:105)
at
at
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean (AbstractAutowireCapableBeanFactory.java:329)
at
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean (AbstractBeanFactory.java:147)
at
at
org.springframework.context.support.AbstractApplicationContext.refresh (AbstractApplicationContext.java:318)
at
at
at
at
at
com.evermind.server.http.HttpApplication.initDynamic(HttpApplication.java :1130)
at
com.evermind.server.http.HttpApplication.(HttpApplication.java:738)
at
com.evermind.server.ApplicationStateRunning.getHttpApplication(ApplicationStateRunning.java :414)
at
at
com.evermind.server.http.HttpSite$HttpApplicationRunTimeReference.createHttpApplicationFromReference (HttpSite.java:1990)
at
at
com.evermind.server.http.HttpSite$HttpApplicationRunTimeReference.getHttpApplication (HttpSite.java:1925)
at
at
at
com.evermind.server.http.HttpRequestHandler.serveOneRequest(HttpRequestHandler.java :216)
at
at
at
at
oracle.oc4j.network.ServerSocketAcceptHandler.procClientSocket(ServerSocketAcceptHandler.java :239)
at
at
oracle.oc4j.network.ServerSocketAcceptHandler$AcceptHandlerHorse.run(ServerSocketAcceptHandler.java :880)
at
at
at
com.sun.media.imageioimpl.common.ImageUtil.processOnRegistration(ImageUtil.java :1414)
at
at
javax.imageio.spi.SubRegistry.registerServiceProvider(ServiceRegistry.java :698)
at
at
at javax.imageio.spi.IIORegistry.(IIORegistry.java:117)
at javax.imageio.ImageIO.( ImageIO.java:46)
… 52 more
any ideas?
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Jdeveloper uses it's own JDK. I installed JAI and IO into this dir. And i
still got problems:
bean with name 'wcs' defined in URL
[code-source:/D:/jdev1013/jdev/mywork/Geoserver-1.5.x/Geoserver/public_html/WEB-INF/lib/wcs-1.5.0-beta1.jar!/applicationContext.xml]:
Can't resolve reference to bean 'data' while setting property 'constructor
[code-source:/D:/jdev1013/jdev/mywork/Geoserver-1.5.x/Geoserver/public_html/WEB-INF/lib/main-1.5.0-beta1.jar!/applicationContext.xml]:
so i guess it might be JAI problem? JAVA_HOME points to the jdeveloper jdk
and my PATH variable contains BNIN dir of jdeveloper jdk. so i have to set a
special variable just for JAI?
Method)
any ideas?
start without it.
your
View this message in context: http://www.nabble.com/spring-framework-problem-tf2958988.html#a8385920
well i changed something. now i get this: ???
16.1.2007 9:30:30 org.apache.commons.digester.Digester getParser
SEVERE: Digester.getParser:
org.xml.sax.SAXNotRecognizedException:
http://apache.org/xml/features/validation/dynamic
  at
oracle.xml.jaxp.JXSAXParserFactory.setFeature(JXSAXParserFactory.java:128)
  at
org.apache.commons.digester.parser.XercesParser.configureXerces(XercesParser.java:185)
  at
org.apache.commons.digester.parser.XercesParser.newSAXParser(XercesParser.java:138)
  at
org.apache.commons.digester.ParserFeatureSetterFactory.newSAXParser(ParserFeatureSetterFactory.java:71)
  at org.apache.commons.digester.Digester.getParser(Digester.java:692)
View this message in context: http://www.nabble.com/spring-framework-problem-tf2958988.html#a8386349
still got problems:
What does it mean into this dir? Did the jars end up in jre/lib/ext?
Is this JDK a Sun one? Does it load whatever is in jre/lib/ext in
the classpath automatically?
SEVERE: Digester.getParser: org.xml.sax.SAXNotRecognizedException:
  at
  at
  at
  at
Ah... your JDK is forcing in a XML parser other than xerces apparently,
and there's an incompatibility. I'm not good enough at XML parsing to
provide a solution, I hope Justin knows more.
Hmmm, nasty. You can try setting the sax parser to be xerces manually on
the command line with the argument. Something like
-Djavax.xml.parsers.SAXParserFactory=org.apache.xerces.jaxp.SAXParserFactoryImpl
-Justin
    at
    at
    at
    at
!DSPAM:1004,45ac9025199351804284693!
Justin Deoliveira
jdeolive@anonymised.com
The Open Planning Project
http://topp.openplans.org
-Justin
  at
  at
  at
  at
!DSPAM:1004,45ac9091199731194215290!
Justin Deoliveira
