[Geoserver-devel] Spring MVC PathVariables cannot parse workspaces
Dear all,
with the latest porting to Spring MVC I noticed a potential issue on Request Mappings.
Long story short with the current definition [http://localhost:8080/geoserver/layers/{layerName}/styles] of PathVariables requests like the following ones
http://localhost:8080/geoserver/layers/geosolutions:my_layer/styles
will fail, since the regex does not recognize that there is a workspace prefix.
Moreover, on restconfig module RequestMappings should, imho, have a ** at the bottom, in order to allow geoserver recognize also extensions.
http://localhost:8080/geoserver/layers/my_layer/styles.xml
http://localhost:8080/geoserver/layers/my_layer/styles.json
which won’t work otherwise. I notices that at least this is has been done on rest module. It should be done on restconfig also.
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
Hi Alessio,
Have you actually tried either of these functionalities out yourself? They both work fine.
In Spring, “:” is treated like any other character, leading to a layerName of “geosolutions:my_layer”. The geoserver catalog already has the necessary functionality to parse the workspace out of a layer name of this form, and does so when looking up the layer.
As for the extensions, spring MVC naturally handles extensions in URLs. This ties into the content-type of the request, and ultimately determines which converter is used to handle the request. If you try it out with the REST API, you will see that adding “.xml” will result in different output than “.json”.
(Also, all your sample URLs are missing “/rest” after “geoserver”)
Torben
On Wed, Oct 4, 2017 at 1:43 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Hi Torben,
are you sure? Maybe it is a problem of my setup then, since with GeoServer 2.12.x I get the following
http://localhost:8080/geoserver/rest/layers/geonode:san_andres_y_providencia_administrative.json
On Fri, Oct 6, 2017 at 1:43 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Alessio,
Torben
Alessio Fabiani
@alfa7691
On Wed, Oct 4, 2017 at 1:43 AM, Alessio Fabiani <alessio.fabiani@anonymised.com…2795…solutions.it> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Geoserver-devel@anonymised.comrge.net
This is currently the customization causing that issue
https://github.com/GeoNode/geoserver-geonode-ext
I had to rewrite the community plugin by removing everywhere “mvc:annotation-driven/”, otherwise there wasn’t the possibility to let it working.
I noticed that GWC still makes use of this annotation-driven support, is there the possibility to get rid of it? Another issue I’m facing with this customization is that at startup GeoServer do not automatically redirects to the Wicket GUI but to the GWC homepage instead.
After a lot of experiments by removing plugins and testing different combinations, I’m afraid that the issue could really be from any “applicationContext.xml” around still making use of “mvc:annotation-driven/”.
Any idea?
On Fri, Oct 6, 2017 at 2:24 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi Torben,
Illegal char <:> at index 15: /layers/geonode:san_andres_y_providencia_administrative.json
[http://localhost:8080/geoserver/rest/layers/san_andres_y_providencia_administrative.json](http://localhost:8080/geoserver/rest/layers/san_andres_y_providencia_administrative.json)
{"layer":{"name":"san_andres_y_providencia_administrative","type":"VECTOR","defaultStyle":{"name":"san_andres_y_providencia_administrative","href":"http:\/\/localhost:8080\/geoserver\/rest\/styles\/san_andres_y_providencia_administrative.json"},"resource":{"@class":"featureType","name":"san_andres_y_providencia_administrative","href":"http:\/\/localhost:8080\/geoserver\/rest\/workspaces\/geonode\/datastores\/san_andres_y_providencia_administrative\/featuretypes\/san_andres_y_providencia_administrative.json"},"queryable":true,"opaque":false,"attribution":{"title":"admin","logoWidth":0,"logoHeight":0}}}
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
Hi Alessio,
Torben
On Wed, Oct 4, 2017 at 1:43 AM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Oh, maybe is this the cause?
java.nio.file.InvalidPathException: Illegal char <:> at index 19: /sldservice/geonode:san_andres_y_providencia_administrative/attributes.xml
at sun.nio.fs.WindowsPathParser.normalize(Unknown Source)
On Fri, Oct 6, 2017 at 9:51 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Any idea?
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 2:24 AM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Hi Torben,
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 1:43 AM, Torben Barsballe <tbarsballe@anonymised.com…3839…> wrote:
Hi Alessio,
Torben
Dear all,
Alessio Fabiani
@alfa7691
Ok, so, after further investigation I should have got the cause of the issue.
Basically this happens when the Monitoring plugin is installed, in particular here
https://github.com/geoserver/geoserver/blob/3518cdb07ec159c1ac365fc8583da7ff4b9da89b/src/extension/monitor/core/src/main/java/org/geoserver/monitor/rest/RESTMonitorCallback.java#L46
Trying to figure out a solution to this issue. Sorry for the noise.
On Fri, Oct 6, 2017 at 1:10 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 9:51 AM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Any idea?
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 2:24 AM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Hi Torben,
Alessio Fabiani
@alfa7691
Hi Alessio,
Torben
Dear all,
Alessio Fabiani
@alfa7691
The GWC home page redirect issue still remains, by the way.
On Fri, Oct 6, 2017 at 1:24 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 1:10 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 9:51 AM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Any idea?
Alessio Fabiani
@alfa7691
Hi Torben,
Alessio Fabiani
@alfa7691
Hi Alessio,
Torben
Dear all,
Alessio Fabiani
@alfa7691
This simple hack will fix the issue
String resource = Paths.get(URLEncoder.encode(request.getPathInfo(), “UTF-8”)).getFileName().toString();
On Fri, Oct 6, 2017 at 1:25 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 1:24 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 1:10 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Alessio Fabiani
@alfa7691
Any idea?
Alessio Fabiani
@alfa7691
Hi Torben,
Alessio Fabiani
@alfa7691
Hi Alessio,
Torben
On Wed, Oct 4, 2017 at 1:43 AM, Alessio Fabiani <alessio.fabiani@anonymised.com.4522…it> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Update on GeoWebCache REST and Web Context conflicts…
JVM needs to start with the following option
-Dgwc.context.suffix=gwc
On Fri, Oct 6, 2017 at 1:43 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 1:25 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 1:24 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
Any idea?
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 2:24 AM, Alessio Fabiani <alessio.fabiani@anonymised.com2…it> wrote:
Hi Torben,
Alessio Fabiani
@alfa7691
Hi Alessio,
Torben
Dear all,
Alessio Fabiani
@alfa7691
We ought to just be using context:component-scan everywhere (without mvc:annotation-driven) if GWC is not doing that, then that is probably an error.
Yes, this was added in the GWC upgrade to MVC. It should be included in the GeoServer gwc configuration (see here) ; if it is not getting picked up then that seems like a bug, or something strange in your configuration.
An issue with the WindowsPathParser seems quite probable, and would explain why I haven’t seen the issue.
Is this likely to cause issues in systems relying upon alternative character sets?
Torben
On Fri, Oct 6, 2017 at 8:33 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 1:43 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 1:25 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 9:51 AM, Alessio Fabiani <alessio.fabiani@anonymised.com22…it> wrote:
Any idea?
Alessio Fabiani
@alfa7691
Hi Torben,
Alessio Fabiani
@alfa7691
Hi Alessio,
Torben
Dear all,
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 6:16 PM, Torben Barsballe <
error.
I was just discussing it with Alessio this morning, a git grep against
current GWC maste shows:
git grep annotation-driven
web/src/main/webapp/WEB-INF/geowebcache-rest-context.xml:
<mvc:annotation-driven/>
web/src/main/webapp/WEB-INF/geowebcache-servlet.xml:
<mvc:annotation-driven />
web/src/main/webapp/WEB-INF/geowebcache-sqlite-context.xml:
<https://github.com/geoserver/geoserver/blob/master/src/gwc/src/main/resources/application.properties&gt;\)
Ah, is this Spring variable interpolation? I found it to be very finicky
when working on multimodule projects,
never totally sure which bean handles them (since often one ends up having
multiple).
attributes.xml
at sun.nio.fs.*WindowsPathParser*.normalize(Unknown Source)
explain why I haven't seen the issue.
Confused though, why is a windows path parser involved in the handling of a
URL to start with...
Alessio, do you have the full stack trace?
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
See responses inline
On Fri, Oct 6, 2017 at 6:29 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Currently this is quite dangerous. If for any reason this variable has no values (and this may happens quite often when using most of the GeoServer extensions redefining PropertyConfigurers) basically there’s a clash between GeoServer and GWC contexts. Also most of the REST calls won’t work due to path clashes.
Here it is
https://bpaste.net/show/2f744b7ae5d2
Alessio Fabiani
@alfa7691
On Fri, Oct 6, 2017 at 6:16 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
I was just discussing it with Alessio this morning, a git grep against current GWC maste shows:
web/src/main/webapp/WEB-INF/geowebcache-rest-context.xml: mvc:annotation-driven/
web/src/main/webapp/WEB-INF/geowebcache-servlet.xml: <mvc:annotation-driven />
web/src/main/webapp/WEB-INF/geowebcache-sqlite-context.xml: mvc:annotation-driven/
Ah, is this Spring variable interpolation? I found it to be very finicky when working on multimodule projects,
never totally sure which bean handles them (since often one ends up having multiple).
Confused though, why is a windows path parser involved in the handling of a URL to start with…
Ing. Andrea Aime
@geowolf
Technical Lead
David Vick and I spoke about this this morning and he thought the annotation-driven elements in the context shouldn’t be necessary. I tried removing them from the GWC stand alone context but that produced a slew of 404 errors in the integration tests.
Alessio Fabiani
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Alessio Fabiani
@alfa7691 Founder/Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 331 6233686 http://www.geo-solutions.it http://twitter.com/geosolutions_it -------------------------------------------------------
On Fri, Oct 6, 2017 at 6:29 PM, Andrea Aime <andrea.aime@anonymised.com268…> wrote:
Here it is
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Kevin Michael Smith
[<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
