Thanks Niels.
2015-03-11 12:19 GMT+01:00 Niels Charlier <niels@anonymised.com>:
It appears in the meantime somebody has already upgraded commons-lang to 2.6 now anyway:
https://github.com/geoserver/geoserver/commit/f89b34a3d7be25d05d053a8d875cf1c2a87504ff#diff-96d5825f70d1b151527c8384ab158bce
so that is one problem solved.
I’ve made a patch to upgrade the LDAP tests to 1.3.2, which fixes the busy port skipping test issue:
https://github.com/geoserver/geoserver/pull/969
Kind Regards
Niels
On 22-02-15 17:28, Andrea Aime wrote:
On Sun, Feb 22, 2015 at 5:10 PM, Niels Charlier <niels@anonymised.com> wrote:
On 21-02-15 19:36, Andrea Aime wrote:
I just tested it seems possible to upgrade the spring ldap test module to 1.3.2 just for the tests, while leaving all the other spring security dependencies how they are. I did have to upgrade apache commons-lang from 2.1 to 2.4 to get it to work.
commons-lang is used in other of places, upgrading it might require going as deep as geotools to check the change is safe for all modules
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
You mean upgrading the version of the ldap test lib? Or both?
It seems that for the non test jar we are getting it via a transitive dependency towards org.springframework.security:spring-security-ldap:
[INFO] ± org.springframework.security:spring-security-ldap:jar:3.1.0.RELEASE:compile
[INFO] | ± org.springframework:spring-tx:jar:3.1.4.RELEASE:compile
[INFO] | - org.springframework.ldap:spring-ldap-core:jar:1.3.1.RELEASE:compile
[INFO] ± org.springframework.ldap:spring-ldap-test:jar:1.3.1.RELEASE:test
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
