[Geoserver-devel] SQL View
I have GeoServer trunk running from eclipse. I could not see the "Configure
new SQL View options when i try to add a new layer. Would it be because I
beta 2.1 is not build off the trunk or am i missing some condition for the
option to appear?
View this message in context: http://old.nabble.com/SQL-View-tp30139377p30139377.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
I have been following the instructions below but got stuck on step 2 :slight_smile:
http://gridlock.openplans.org/geoserver/trunk/doc/en/user/data/sqlview.html
"Configure new SQL View options when i try to add a new layer. Would it be
because I beta 2.1 is not build off the trunk or am i missing some
condition for the option to appear?
View this message in context: http://old.nabble.com/SQL-View-tp30139377p30157438.html
On Mon, Nov 8, 2010 at 3:17 AM, VT@anonymised.com <victor.tey@anonymised.com> wrote:
Just tried, the option to create a new view is there is you go to
layers/add new layer,
but not in the page you get after adding a new data store.
Would be nice to have it there too (patches welcomed! :slight_smile: ).
The instructions above however use the layer -> new layer workflow, also as
shown by the fact you have a store chooser, which is not there when you are in
the "create new store" workflow
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
