[Geoserver-devel] SQL views and performance
Some questions about Geoserver performances when using SQL views as layers. I've got many layers that are defined from SQL views directly on Geoserver (no viewson the database), from Postgres. It seems that each time the Geoserver receive a query (single WMS, or multi WMS coming from tiled queries in OpenLayers), it does the wole SQL query for each GET. And then return the image from the BBOX.
When I query a GetMap for a small area, the whole country is queried just to have a small extent.
I tried a new SQL view with a %polygon% attributes : this adds "AND ST_Intersects() " between the geometry from this polygon, and the geometry of the table. Now I have a strange change :
- for largest images (a whole city), the return time for GetMap is divided by 6 (6000ms -> 1000ms)
- for smallest images (a district), the return time for GetMap is multiplied by 3 (100ms -> 300ms)
The SQL with the ST_Intersects and the Bbox takes 300ms, so I guess the GetMap won't be faster than this...
Thanks for the advice !
Gabriel Vatin
Hi Gabriel,
it seems your database of choice has real trouble figuring out a good access plan
for those queries. Hard to say if the db should be able to just figure out that the
outer spatial index can be executed directly in the inner query or not without seeing the query.
Normally postgis/postgresql is pretty good with planning, while Oracle and SQL Server are
rather poor.
Some systems allow to add a place where the current “bbox” can be expanded as a parameter
transparently (without explicit support). GeoServer could have it too with some development effort:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
That said, in your case it seems it’s not always a win, I guess it’s a matter of figuring out
how many zoomed in vs zoomed out requests you need to produce.
Maybe you could create two views, one with, one without, bind them in a layer group, and use scale dependencies to
switch from one to the other.
On Mon, Mar 20, 2017 at 3:55 PM, Gabriel Vatin <gabriel.vatin@anonymised.com> wrote:
layers. I’ve got many layers that are defined from SQL views directly on
  • for largest images (a whole city), the return time for GetMap is
    divided by 6 (6000ms → 1000ms)
  • for smallest images (a district), the return time for GetMap is
    multiplied by 3 (100ms → 300ms)
GetMap won’t be faster than this…
Gabriel Vatin
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks Andrea for the quick answer. What I can’t really guess for now, is when and how is the SQL view executed : does the BBOX attribute of GetMap queries affect this SQL view (when no parameter in the view definition) ?
The type of query to create a new layer is done so : I have a whole “goi” table with attributes such as name etc., and a table with all geometries (stored in geo_data column, which is a Geometry,4326 with GIST index). Each layers of my GeoServer changes with the “got_id” (layer theme ID), stored on the goi table. Here is the whole view
SELECT id, id_ori, name, geo_data
FROM geometrie
LEFT JOIN goi USING (goi_id)
WHERE got_id = 105
I add this extra line for the 2nd version, where the POLYGON is view parameter generated from the client :
AND St_Intersects(geo_data,St_Transform(ST_GeomFromText(‘POLYGON((808771 5420870,810771 5420870,810771 5422870,808771 5422870,808771 5420870))’,3857),4326))
(attachments)
Le 20/03/2017 à 17:00, Andrea Aime a écrit :
Hi Gabriel,
rather poor.
Gabriel Vatin
Geoserver-devel@anonymised.comsourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Kinaxia
Gabriel VATIN
Docteur en Géomatique
Ingénieur de recherche
Tél : 06.63.92.94.42
Email : gabriel.vatin@anonymised.com
http://www.kinaxia.fr
Hi Gabriel,
If you turn the GeoServer logging level to Geotools-developer level, the log file will then include the SQL query that is sent to the database. This should facilitate debugging this issue.
You can then try running the query against your database’s EXPLAIN syntax - which shows how your database thinks it will run it (or even better, EXPLAIN ANALYZE, which runs it and then says how it ran it). This will let you try and determine where the bottleneck is.
I’ve found this to be a fairly decent tutorial: https://www.depesz.com/2013/04/16/explaining-the-unexplainable/]
Between these you should hopefully be able to determine whether the optimisation scope is GeoServer, PostGres, your query, or some combination thereof.
Jonathan
---- On Mon, 20 Mar 2017 17:34:03 +0000 Gabriel Vatin gabriel.vatin@anonymised.com wrote ----
FROM geometrie
WHERE got_id = 105
Hi Gabriel,
rather poor.
Gabriel Vatin
Ing. Andrea Aime
@geowolf
Technical Lead
Kinaxia
Gabriel VATIN
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
On Mon, Mar 20, 2017 at 6:34 PM, Gabriel Vatin <gabriel.vatin@anonymised.com>
wrote:
Thanks Andrea for the quick answer. What I can't really guess for now, is
Yes, just like any other table. With a plain table the query composed is:
select <fields> from <theTable> where <Filters>
where <filters> comes from the OGC request, that is, the bbox, time,
elevation, and the SLD itself.
When working off a sql view it becomes:
select <fields> from (<theSqlViewDefinition>) as _gt_table where <Filters>
In other words, GeoServer uses the SQL you provided verbatim (could be a
stored procedure call too, or whatever database specific mechanism returns
a set of rows) and then applies filters on it.
This should not be interpreted as running sql view definition first and
then filtering on top of it, it's up to the database to figure out an
optimal execution order, depending on the sql involved and database
abilities the bbox filter might be run first before doing the joins in your
sql, and so on. See also https://en.wikipedia.org/wiki/Query_plan
The type of query to create a new layer is done so : I have a whole "goi"
layers of my GeoServer changes with the "got_id" (layer theme ID), stored
FROM geometrie
WHERE got_id = 105
See Jonathan's mail about getting the full query and running an explain.
It might just well be that you have index statistics that are out of date,
too, running a "analyze" might help:
https://www.postgresql.org/docs/9.1/static/sql-analyze.html
Ing. Andrea Aime
@geowolf
Technical Lead
Great, thanks to both of you. Now I see clearer on how to debug and improve this. If I get something that would be useful to all, after improving the queries, I’ll share the trick!
Gabriel
(attachments)
Le 21/03/2017 à 12:58, Jonathan Moules a écrit :
Hi Gabriel,
Jonathan
FROM geometrie
WHERE got_id = 105
Hi Gabriel,
rather poor.
Gabriel Vatin
Geoserver-devel@anonymised.com.net
Ing. Andrea Aime
@geowolf
Technical Lead
Kinaxia
Gabriel VATIN
Email : gabriel.vatin@anonymised.com18…
Kinaxia
Gabriel VATIN
