Hi, i noticed that using
<ogc:BBOX> filter == .Filter
<ogc:Intersects> == STIntersects
The mapping can be found in SQLServerFilterToSQL.visitBinarySpatialOperator.
Because of the use of .Filter, <ogc:BBOX> seem to be returning me the wrong
error.
<ogc:BBOX>
<ogc:PropertyName>er:location</ogc:PropertyName>
<gml:Envelope srsName="EPSG:4326">
<gml:lowerCorner>114 30</gml:lowerCorner>
<gml:upperCorner>115 31</gml:upperCorner>
</gml:Envelope>
</ogc:BBOX>
From the sqlserver, running the following query generated as a result of the
above bbox using .FILTER returns me
SELECT
CAST("LOCATION".STSrid as VARCHAR) + ':' + "LOCATION".STAsText() as
"LOCATION"
FROM "ER_MININGFEATUREOCCURRENCE"
WHERE "LOCATION".Filter(geometry::STGeomFromText('POLYGON ((114 30, 114 31,
115 31, 115 30, 114 30))', 4326)) = 1
4326:POINT (117.3255 -35.03178)
4326:POINT (117.573097 -35.05859)
4326:POINT (117.791397 -35.041531)
4326:POINT (117.140676 -35.044455)
4326:POINT (117.325104 -35.03162)
which is way out of range. Changing it to the use of ogc:Intersects yields
the correct result. So is it really accurate to use BBOX with .FILTER?
I post my question to the sqlserver forum and this is their reply
This is expected behaviour - you're using the Filter() method, which
performs only a primary filter of the records from the table - this is a
fast, approximate method that returns a superset of those points that
intersect the supplied polygon.
If you want only those points from the table that definitely intersect the
polygon, use STIntersects() instead of Filter()
View this message in context: http://old.nabble.com/sqlserver-BBox-%3D%3D-Filter-incorrect-result-returned-tp30860541p30860541.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
