Hi Andrea
I had few issues with complex feature and now a days exploring the feasibility of SQLView to satisfy the requirement. SQLView works well with one or more tables with normal SQL statements.
Today i was try to use SQL statement with SDO_AGGR_UNION to combine all the polygons which are related and when i did refresh link to load fields in configuration page, i got the exception given below. I’m going to have look the code for this issue and possible fixes for that. it looks issue with SQL conversion. However your advice/guidelines on this issue is much appreciated.
Thanks
regards
Senthil
SQL Query used in SQLView:
SELECT b.group_Id, SDO_AGGR_UNION(SDOAGGRTYPE(a.LOCATION, 0.005)) FROM GIS.PART_TABLE a, GIS.MAP_TABLE b WHERE a.PART_ID=b.PART_ID Group by b.group_Id
14 Jul 16:53:45 DEBUG [org.geotools.jdbc] - SELECT * FROM (SELECT SDO_AGGR_UNION(SDOAGGRTYPE(A.L as SDO_AGGR_UNION(SDOAGGRTYPE(A.L FROM (SELECT b.group_Id, SDO_AGGR_UNION(SDOAGGRTY
PE(a.LOCATION, 0.005)) FROM GIS.PART_TABLE a, GIS.MAP_TABLE b WHERE a.PART_ID=b.PART_ID Group by b.group_Id) VTABLE) WHERE ROWNUM <= 1
14 Jul 16:53:45 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
14 Jul 16:53:45 ERROR [org.apache.wicket.RequestCycle] - java.io.IOException
java.lang.RuntimeException: java.io.IOException
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:212)
at org.geoserver.web.data.layer.SQLViewAbstractPage.guessFeatureType(SQLViewAbstractPage.java:373)
at org.geoserver.web.data.layer.SQLViewAbstractPage.testViewDefinition(SQLViewAbstractPage.java:306)
at org.geoserver.web.data.layer.SQLViewAbstractPage$8.onClick(SQLViewAbstractPage.java:269)
at org.geoserver.web.wicket.GeoServerAjaxFormLink.onSubmit(GeoServerAjaxFormLink.java:39)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:94)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:128)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:163)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:297)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:104)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1239)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:532)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:145)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:859)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:579)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1555)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.io.IOException
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:558)
at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:483)
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:209)
… 79 more
Caused by: java.sql.SQLException: ORA-00907: missing right parenthesis
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:331)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:288)
at oracle.jdbc.driver.T4C8Oall.receive(T4C8Oall.java:743)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:216)
at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:799)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1037)
at oracle.jdbc.driver.T4CPreparedStatement.executeMaybeDescribe(T4CPreparedStatement.java:839)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1132)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3316)
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3361)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
at org.geotools.jdbc.JDBCFeatureReader.(JDBCFeatureReader.java:158)
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:546)
… 81 more
14 Jul 16:53:45 WARN [org.geotools.jdbc] - There is code leaving feature readers/iterators open, this is leaking statements and connections!
