[Geoserver-devel] SRS and Datastore
dblasby: pramsey - it depends on the datastore. If its
         giving me data in 4326, then I just use what it gives me.
  if there's atransform, its up to the CRS xforms to handle it.
  (sorry, have to go)
Isn't the EPSG code part of the FeatureType configuration? IE, the person configuring geoserver is specifying it, based on their knowledge of the backend system? Does the data come straight out of the backend system and get tagged with this info, or is there a transform between the datastore SRS and the user provided output SRS? If the latter, thanks to Martin's magic SRS code, things might actually work.
