[Geoserver-devel] srsName encoding
Hi List,
Since I am not sure if this is a geoserver / geotools related issue, thus submitting it to both list.
What I would like to find out here is regarding the srsName encoding base on the srid from the database.
The use case :
sa:samplingLocation
<gml:LineString srsName=“http://www.opengis.net/gml/srs/epsg.xml#4283”>
gml:posList141.0 NaN 142.0 NaN</gml:posList>
</gml:LineString>
</sa:samplingLocation>
Base on the above use case, the srsName is encoded with prefix “http://www.opengis.net/gml/srs/epsg.xml#” + srid from the user_sdo_geom_metadata table in oracle database. What I would like to achieve here is to have srsName encoded as “http://www.opengis.net/def/crs/EPSG/0/4283”, the later srsNamer is actually resolvable and the first one are not. This srsName is base on the OGC spec : OGC 09-048r3: “Name type specification – definitions – part 1 – basic name” (http://www.opengeospatial.org/ogc/policies/directives).
Question here is can request to replace the prefix which is hardcoded in geoserver / geotools ?
Florence Tan
Software Engineer | Auscope Grid
CSIRO Earth Science and Resource Engineering
Phone: +61 8 6436 8802 | Fax: +61 8 6436 8559
florence.tan@anonymised.com | www.csiro.au
Address: Australian Resources Research Centre, 26 Dick Perry Avenue, Kensington WA 6151
PLEASE NOTE
The information contained in this email may be confidential or privileged. Any unauthorised use or disclosure is prohibited. If you have received this email in error, please delete it immediately and notify the sender by return email. Thank you. To the extent permitted by law, CSIRO does not represent, warrant and/or guarantee that the integrity of this communication has been maintained or that the communication is free of errors, virus, interception or interference.
Please consider the environment before printing this email.
