how does it determine that the srsName is "urn:x-ogc:def:crs:EPSG:4326"?
is it derived from the database? if so then how does it know to append
urn:x-ogc:def:crs
my featureType.xml (I changed it to 4327 on purpose) holds
<srs>EPSG:4327</srs>
<crs>EPSG:4327</crs>
how does it determine that the srsName is "urn:x-ogc:def:crs:EPSG:4326"? is it derived from the database? if so then how does it know to append
urn:x-ogc:def:crs
That is forced in by the usage of WFS 1.1. It's the official way to express the SRS, everything that's encoded in GML3 is using the urn form
unless the user explicitly asks for a reprojection (in which case you
may end up with EPSG:XYWZ form if that's what the user asked for).
There is no way to configure the GML3 output to use any of the old
SRS expressions. Afaik a server would not pass the CITE tests
if it was using those.
Andrea Aime
OpenGeo - http://opengeo.org
