[Geoserver-devel] Standardize URL of WMS endpoint in GetCapabilities response
I found a new funny detail from WFS specs. Have a look at WFS 1.1.0 standard:
The element is used to request a capabilities document from a web feature service.
It is defined by the following XML Schema fragment:
<xsd:element name=“GetCapabilities” type=“wfs:GetCapabilitiesType”/>
<xsd:complexType name=“GetCapabilitiesType”>
xsd:complexContent
<xsd:extension base=“ows:GetCapabilitiesType”>
<xsd:attribute name=“service” type=“ows:ServiceType”
use=“optional” default=“WFS”/>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
Notice that “service” is optional. Because of that the /ows endpoint can’t be used because Geoserver can’t guess the requested service. Indeed it is responding with an exception which is easy to test with http://demo.opengeo.org/geoserver/ows?request=getcapabilities
However, the developers have been reading the standards carefully and this request is accepted:
http://demo.opengeo.org/geoserver/wfs?request=getcapabilities
I would call this as a bug in WFS 1.1.0 and indeed in WFS 2.0.0 the schema is different and “service” is required
xsd:complexContent
<xsd:attribute name=“service” type=“ows:ServiceType” use=“required” fixed=“WFS”/>
</xsd:extension>
</xsd:complexType>
I hope that nobody has ever made a WFS client that does not send &SERVICE=WFS just because it is optional in WFS 1.1.0 probably due to some copy-paste error.
-Jukka Rahkonen-
Andrea Aime wrote:
On Tue, Mar 15, 2016 at 3:46 PM, Damiano Albani <damiano.albani@…467…> wrote:
Yes, it would be nice to have that discussion about the service endpoints.
Although the current behavior provides a lot a flexibility (simply by adding the appropriate “&service=XYZ”), it makes things messy and not very logical in my opinion.
A concrete example of where this is an issue, is when trying to limit access to specific protocols, when GeoServer is running behind a reverse proxy.
Ah, now this is a problem, because we cannot stop responding to the old paths either, it would be a severe backwards compatibility issue.
But as you said that the “correct” endpoint URL is “/ows?SERVICE=XYZ&”, that means that such a reverse proxy would have to check the query parameters anyway.
Right. Securing OGC protocols by reverse proxy is going to be a lot of pain anyways, think also about the POST requests
that are accepted in most protocols (yes, also in WMS).
A few year ago we looked into it and decided that going the “security proxy” was going to be too much of a pain, and
developed a different approach instead:
http://demo.geo-solutions.it/share/securing_geoserver.pdf
I’d suggest you have a look at the ResourceAccessManager interface, the default security subsystem implementation
possibly to GeoFence as examples of implementation of that concept.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
