Should the start.jar not be inside the "geoserver-bin.zip\geoserver\bin", it is currently in the "geoserver-bin.zip\geoserver". If it is I will move it.
Kind Regards
Clint Lewis
Kind Regards
Clint Lewis
It is left in the root because this they way it is if you download jetty and try to run geoseserver out of the box. So someone could point use their own installation of jetty if they choose just by setting GEOSERVER_HOME.
We just need to update the windows batch script correctly. I have tried but cant test it :).
-Justin
Clint Lewis wrote:
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
it should be in \bin
Brent Owens
(The Open Planning Project)
Clint Lewis wrote:
We moved it out so that the starup.sh script will work with jetty already installed on someones machine (which has no bin directory) instead of forcing people to use our built in jetty support.
-Justin
Brent Owens
(The Open Planning Project)Clint Lewis wrote:
All the advantages of Linux Managed Hosting--Without the Cost and Risk!
Fully trained technicians. The highest number of Red Hat certifications in
the hosting industry. Fanatical Support. Click to learn more
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=107521&bid=248729&dat=121642
Geoserver-devel mailing list
Justin Deoliveira
ah, ok.
Brent Owens
-Justin
Brent Owens
