jive
1
Yep I know Andrea volunteered for this one. Chatting with Kevin it makes sense to start this one first from a GWC point of view.
Here are the revisions from a passing cite test:
GeoTools 12…2 / GeoServer 2.6.2
version = 2.6-SNAPSHOT
git revision = d8d01ae1fb41132bc15794670834c5606fdfa991
git branch = d8d01ae1fb41132bc15794670834c5606fdfa991
build date = 19-Jan-2015 17:58
geotools version = 12-SNAPSHOT
geotools revision = a0d72ab4ab784e922921e36cebdc79f0f44932fe
geowebcache version = 1.6-SNAPSHOT
geowebcache revision = fabd9c17c9b1f07e654b70b93dfeea532ad03b39/fabd9
hudson build = 159
I will keep the mailing list advised, and start a seperate thread for 2.7-beta.
Jody Garnett
jive
2
Looks like 2.6.x also needs more memory to build javadocs:
[ERROR] javadoc: error - java.lang.OutOfMemoryError: Please increase memory.
[ERROR] For example, on the JDK Classic or HotSpot VMs, add the option -J-Xmx
[ERROR] such as -J-Xmx32m.
I will grab the patch from master.
On 19 January 2015 at 12:24, Jody Garnett <jody.garnett@anonymised.com> wrote:
hudson build = 159
Jody Garnett
Jody Garnett
jive
3
Patch worked, 12.2 is deployed. Over to you Kevin for GWC 1.6.1.
On 19 January 2015 at 13:29, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
hudson build = 159
Jody Garnett
jive
5
Thanks I will start the 2.6.2 build for Andrea then.
On 19 January 2015 at 17:17, Kevin Smith <ksmith@anonymised.com> wrote:
GWC 1.6.1 is deployed.
Jody Garnett
On 19 January 2015 at 16:20, Jody Garnett <jody.garnett@anonymised.com> wrote:
Kevin Smith
Junior Software Engineer | Boundless
+1-778-785-7459
@boundlessgeo
Jody Garnett
Jody Garnett
hudson build = 159
Jody Garnett
jive
6
2.6.2 is available for testing:
[http://ares.boundlessgeo.com/geoserver/release/2.6.2](http://ares.boundlessgeo.com/geoserver/release/2.6.2)
On 19 January 2015 at 17:24, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
Kevin Smith
+1-778-785-7459
@boundlessgeo
Jody Garnett
Jody Garnett
hudson build = 159
Jody Garnett
