[Geoserver-devel] Starting Mainenance Release for GeoServer 2.18.5 / GeoTools 24.5
Hi All,
As per subject Andrea and I are moving on with the release. I’ll keep you posted on the progress
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
https://www.geosolutionsgroup.com
https://twitter.com/geosolutions_it
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi All,
Artifacts for GeoServer 2.18.5 are available for testing here. Please test them and report any issue
Note: there has not been any commit for GWC so no GWC release and we sticked to version 1.18.4
Thank you,
Alessandro
On Wed, Aug 18, 2021 at 9:29 AM Alessandro Parma <alessandro.parma@…6887…> wrote:
Hi All,
Alessandro Parma
Alessandro Parma
DevOps Engineer
Alessandro Parma
Alessandro Parma
DevOps Engineer
<https://build.geoserver.org/view/release/job/geoserver-release/lastSuccessf
ulBuild/artifact/distribution/2.18.5/>. Please test them and report any
issue
Thanks for the release work.
I booted the war file on Ubuntu / Tomcat 9. Seems fine. Checked a couple of
layer previews in OL, and Tasmania in KML on Google Earth.
Brad
Thanks for testing Brad
I am moving on with artifacts publishing. They should be available soon
Alessandro
issue
Brad
Geoserver-devel mailing list
Alessandro Parma
Alessandro Parma
DevOps Engineer
Alessandro:
I cannot see the geotools 24.5 release artifacts published to the osgeo nexus repository - the following search does not show any content.
Checking the user list I did not see a release announcement for geotools user list so I am not sure if you finished that step? Actually there is a blog post from Andrea.
Please advise.
Jody Garnett
Andrea notes that the source forge download page has content, so it is a mystery why the artifacts are not available on nexus.
To resolve this I have downloaded the 24.5 project from sourceforge, and deployed to nexus from my local machine.
Jody Garnett
Hi Jody,
Thanks for pushing them!
I tried to have a look at the jenkins job logs for the release to understand if there had been any problems but the builds were
discarded after 30 days.
Alessandro
Alessandro Parma
Alessandro Parma
DevOps Engineer
