[Geoserver-devel] Starting Maintenance Release Train
Hi All,
Just to let you know that I am starting the release for the following:
  • GeoTools 24.4
  • GeoWebCache 1.18.4
  • GeoServer 2.18.4
I’ll keep you posted on the progress!
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
GeoTools 24.4 artifacts are available on sourceforge . Thank you for testing!
On Fri, Jun 18, 2021 at 4:55 PM Alessandro Parma <alessandro.parma@anonymised.com> wrote:
Hi All,
  • GeoTools 24.4
  • GeoServer 2.18.4
Alessandro Parma
Alessandro Parma
DevOps Engineer
Alessandro Parma
Alessandro Parma
DevOps Engineer
Testing the artifacts, they are as expected.
The only thing (not unique to this release) that may not work is the project download VERSION.txt
The placeholder content probably will not be filled in with the git revision as this is not available:
version: ${project.version}
git revision: ${build.commit.id}
build date: ${build.timestamp}
Thanks for working on the release Alessandro.
Jody Garnett
Hi All,
Artifacts for GeoServer are available here for testing. Thank you Jody for testing GT!
On Sat, Jun 19, 2021 at 1:58 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Fri, 18 Jun 2021 at 10:40, Alessandro Parma <alessandro.parma@…1268…> wrote:
On Fri, Jun 18, 2021 at 4:55 PM Alessandro Parma <alessandro.parma@anonymised.com8…> wrote:
Hi All,
  • GeoTools 24.4
  • GeoServer 2.18.4
Alessandro Parma
Alessandro Parma
DevOps Engineer
Alessandro Parma
Alessandro Parma
DevOps Engineer
GeoTools-Devel mailing list
GeoTools-Devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Alessandro Parma
Alessandro Parma
DevOps Engineer
