[Geoserver-devel] Starting the Release for GeoServer 2.18.1 / GeoTools 24.1
I tried bin-zip on Windows and OpenJDK 11 looks mostly ok.
The SRS list demo has some problem, should be easy to reproduce by selecting EPSG:4326 and zooming on the map view. That is producing this kind of log into my console:
Caused by: java.io.IOException: Read Channel is not a File Channel so this is not possible.
at org.geotools.data.shapefile.fid.IndexedFidReader.goTo(IndexedFidReader.java:233)
at org.geotools.data.shapefile.ShapefileFeatureReader.buildFeatureId(ShapefileFeatureReader.java:290)
at org.geotools.data.shapefile.ShapefileFeatureReader.buildFeature(ShapefileFeatureReader.java:258)
at org.geotools.data.shapefile.ShapefileFeatureReader.hasNext(ShapefileFeatureReader.java:194)
at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.hasNext(ContentFeatureCollection.java:138)
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Lähetetty: perjantai 20. marraskuuta 2020 9.56
Vastaanottaja: Alessandro Parma <alessandro.parma@…1268…>
Alessandro:
All good so far: tested bin download and docs, with ysld extension.
Noticed one odd thing, probably not new? When visiting the server status page the logs are filled up with a block of INFO:
INFO: ===============================================================================
INFO: Marlin software rasterizer = ENABLED
INFO: Version = [marlin-0.9.3-Unsafe]
INFO: sun.java2d.renderer = org.marlin.pisces.MarlinRenderingEngine
INFO: sun.java2d.renderer.useThreadLocal = true
INFO: sun.java2d.renderer.useRef = soft
INFO: sun.java2d.renderer.edges = 4096
INFO: sun.java2d.renderer.pixelWidth = 4096
INFO: sun.java2d.renderer.pixelHeight = 2176
Importantly the System Status information is working correctly, this was not the case for 2.18.0 on macOS 11.
Thanks for making the release!
aside: I have an additional “state of geoserver” presentation to share for the release announcements
Jody Garnett
On Thu, 19 Nov 2020 at 09:22, Alessandro Parma <alessandro.parma@…1268…> wrote:
Hi All, Jody
Artifacts are available for testing here any feedback is welcome.
On Wed, Nov 18, 2020 at 9:10 AM Alessandro Parma <alessandro.parma@…1268…> wrote:
Hi All,
Just to let you know that I’m starting the release procedure for
  • GeoServer 2.18.1
  • GeoWebCache 1.18.1
  • GeoTools 24.1
I’ll keep you posted on the progress
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Alessandro Parma
Alessandro Parma
DevOps Engineer
Hi Jukka,
is that something you see in the logs only, but does not break the page per se?
I think I’m seeing something similar, with the world map not showing in the OL preview of the valid area,
but just the valid area itself
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
