[Geoserver-devel] Starting the Release for GeoServer 2.18.2 / GeoTools 24.2
Hi All,
As per subject I started working on the release for GeoServer 2.18.2 scheduled for today, Jan the 18th.
I’ll keep you posted
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Pretty smooth so far. Artifacts available for testing here, feedback is welcome
Platform independent binary is starting up without any issues, thanks @Mark Prins
Alessandro Parma
Alessandro Parma
DevOps Engineer
