[Geoserver-devel] Status of the CSS extension?
as you might be aware I’m working on the gt-css module, which should provide more or less
the same functionality of the GeoScript scala css support.
Now, the current css module in GeoServer relies on the Scala code, and I’m preparing
a patch to have it work against either the Scala code or the gt-css one depending
on what it finds in the classpath.
However, given that the Scala CSS support has not seen any activity in a long time,
and hearing on twitter that apparently that the latest version of the OpenGeo suite
dropped support for CSS I’m wondering if I’m just overthinking it, and I should
go for a direct replacement.
David, are you around, care to comment?
In case we don’t hear from David, what do you suggest we should do?
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Unless you or someone else will be picking up the maintenance for the scala CSS module, I’d say go ahead and drop it.
If someone does begin updates/maintenance to the scala version in the future, you can always come back and implement the check for which to use later.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@...3926...
(attachments)
Ing. Andrea Aime
@geowolf
Technical Lead
Right, I’m not using the CSS extension myself these days and with OpenGeo Suite moving to ySLD I expect that the Scala implementation is dead for good. I would say it’s not worth the added complexity to try and support both in GeoServer.
On Wed, Dec 17, 2014 at 7:27 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
David Winslow
Software Engineer | Boundless
dwinslow@anonymised.com
917-388-9085
@boundlessgeo
On Wed, Dec 17, 2014 at 4:03 PM, David Winslow <dwinslow@anonymised.com>
wrote:
Right, I'm not using the CSS extension myself these days and with OpenGeo
good. I would say it's not worth the added complexity to try and support
both in GeoServer.
Thank you David, this surely simplifies things
Ing. Andrea Aime
@geowolf
Technical Lead
It was not dropped from OpenGeo Suite. CSS module is the extension list for the enterprise edition.
On 17 December 2014 at 04:27, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
On Wed, Dec 17, 2014 at 6:37 PM, Jody Garnett <jody.garnett@anonymised.com>
My bad. I guess this conversation was referring to the free version then:
https://twitter.com/MappingGIS/status/543428977021702144
Ing. Andrea Aime
@geowolf
Technical Lead
