See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today! http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Hi Andrea: Were you able to get your fix in? Reading through the commits logs it appears several fixes to KML and GeoSearch have been applied. In the absence of further direction from you I am going to sire up the release engines….
I note that cite-wfs (which I normally use to check) is still hanging back at an older GeoTools version.
On Sat, Jul 20, 2013 at 3:25 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
engines….
