[Geoserver-devel] Strange problems with png8 image format and transparency=true requests
First : Sorry for cross-posting, but I have no idea where the problem occurs and geoserver is based on geotools.
After the fix of bug UDIG-1650 (transparency and image format png8) the labels of rendered features are ugly. What I’ve done:
  • checked out response from geoserver 2.0.x with image format png8 and transparency
    png (attachment transpatent-png.png):
http://localhost:8092/geoserver/wms?bbox=-130,24,-66,50&styles=&Format=image/png&request=GetMap&layers=utm_grp&width=550&height=250&srs=EPSG:4326&transparency=true
png8 (attachment transpatent-png8.png):
http://localhost:8092/geoserver/wms?bbox=-130,24,-66,50&styles=&Format=image/png8&request=GetMap&layers=utm_grp&width=550&height=250&srs=EPSG:4326&transparency=true
What is the reason of this kind of ugly labels if transparency is set to true? If the request is without the transparency parameter both pictures are equal and looking like wms.png. Do you have any suggestions why this happens?
Is it probably an imageIO problem, a renderer option (anti-aliasing or something like that) problem?
Frank
(attachments)
Frank Gasdorf ha scritto:
After the fix of bug UDIG-1650 <http://jira.codehaus.org/browse/UDIG-1650&gt; (transparency and image format png8) the labels of rendered features are ugly. What I've done:
- checked out response from geoserver 2.0.x with image format png8 and transparency
I already answered you on the uDig lists. Quoting:
Labels use antialising heavily, when we do color reduction to 256 colors
that will suffer inevitably, especially with transparent output.
There is nothing easy that can be done for that unfortunately,
we'd need a color reduction algorithm that supports alpha in the
palette, something that an open source project, pngnq, does, but
it's not trivial at all to port over.
I'd estimate it would take 3-5 days of work for a developer
that knows _very_ well its way in the raster data manipulation
algorithms and will probably result in a 2-10 times slowdown
compared to the current color reduction algorithm
Andrea Aime
OpenGeo - http://opengeo.org
