Yes I’ve tried upping the memory to Maven and Surefire with no change and tweaking the tests is how I figured out that the extra Folder element was the problem.
The WFS error is related to the entity resolution security fix.
org.xml.sax.SAXException: Entity resolution disallowed for file:/home/smithkm/og-proj/geoserver/src/ows/target/classes/org/geoserver/ows/xml/v1_0/owsAll.xsd
Hi Kevin,
you might want to modify those tests and set a higher logging level, in order to get
more information?
If that only happens during a long build it could also have to do with permgen or heap
settings, I know I recently had to kick the testing heap up to 512MB in order to make
the build work on ares.
On Tue, Oct 6, 2015 at 4:13 AM, Kevin Smith <smithkm@anonymised.com> wrote:
I’ve been getting some strange unit test failures that only seem to
occur on my machine.
Some in the WFS module that appear and disappear depending on how the
tests are run.
org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithMatchingUrnBboxFilter()
org.geoserver.wfs.v1_1.GetFeatureTest.testWithSRS()
org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithBboxFilter()
org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithBoundsEnabled()
org.geoserver.wfs.v1_1.GetFeatureTest.testWithSillyLiteral()
org.geoserver.wfs.v1_1.GetFeatureTest.testWithGmlObjectId()
If I run all the GeoServer unit tests, they fail, but if I just run the
WFS Module by itself, or resume from :gs-wfs they pass. In Eclipse,
running the WFS module’s tests together fails, but running the tests
individually passes. They all seem to be caused by service exceptions.
The other test is failing consistently:
org.geoserver.wps.ogr.WPSOgrTest.testOGRKMLOutputExecuteDocument()
It’s checking that there’s a node in the XML matching
“//kml:kml/kml:Document/kml:Schema”, but the the Schema node is inside a
Folder node inside the Document node rather than a direct child. I
don’t know if this is a mistake in the test or if that extra element is
an error. If the folder is acceptable it’s easy enough to correct the
XPath to "//kml:kml/kml:Document/kml:Schema |
//kml:kml/kml:Document/kml:Folder/kml:Schema" which will work either
way.
The WFS failures have been plaguing me on and off for over a month. The
OGR-WPS failure is new.
Kevin Michael Smith
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
