On Wed, Mar 28, 2018 at 1:16 PM, Frank Gasdorf <fgdrf@anonymised.com>
wrote:
The intention is to get an application running without JAI which implies
to have no raster support. This is fine for the first shot and maybe helps
to transform StreamingRenderer "god-class" to something
that is easier to maintain and might opens up chances to configure systems
(plug-able)
Hmm... I doubt it will serve your specific purpose, the raster rendering is
already factored out in GridCoverageRenderer,
although, going by memory, there are still lingering bits in the rendering
transformations paths.
About a refactor, please don't unless it's absolutely necessary or you're
going to become the new maintainer of the module,
I'm not trying to pick on you but I had enough of people coming with big
"I'll make it better for you" refactors and then
walking away, leaving me to struggle for months (or years, in the case of
the WMS module refactor) trying to figure out
where functionality is gone and how I'm supposed to extend the new model.
st finding : the rabbit hole is quite hidden and I'mn still looking for
it. Are you saying it would help to add a test-case first that might fail
all the time to force refactorings?
Yes, a module that only contains a test and sets up the classpath in such a
way that JAI is guaranteed not to be there,
with one or more tests checking your use case.
If this is not in the build your work will degrade over time with nobody
noticing.
have you heard about similiar requirments or even opposite in any way?
I heard Jody speaking about it, but no,personally never had the need, nor
had on behalf of a customer.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
