[Geoserver-devel] Stumbled into a continuous code review tool
I don’t have direct experience with this product, but our company has the Checkstyle and PMD checks implemented through our check-in process with Stash.
Sputnik does seem to be free for public repositories.
Speaking strictly for myself:
  1. The initial period after adding the tools makes human readable pull requests a little more difficult as the PMD and Checkstyle add comments to every line they find against defined styles and “acceptable” coding practices.
a. E.g.
String my_variable = “SomeThing”;
String my_other_variable = “SomeThing”;
String my_last_variable = “SomeThing”;
String my_forgot_to_add_variable = “SomeThing”;
Generates a message on each line indicating that private variables should not have underscores in them. Makes reading the code a little more difficult.
  1. There needs to be buy-in or at least resignation to use :slight_smile: the styles that are enforced via the tools. Once the initial set of required changes are made to be in compliance, the tools help maintain a consistent style across the codebase.
If the styles are available publicly for setup, then tools such as IntelliJ ™ can run the identical checks on change sets before pushing to the main repository.
My $.04
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@...3926...
(attachments)
just stumbled into this one:
https://sputnik.ci/
Looks like it would apply automatic code reviews to pull requests… sounds
tempting, although I guess it might be annoying for a while, not sure
the thing can review just the changed lines…
Experiences, opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
