The fix [1] for issue GEOS-7930 [2] changed the order of operations performed to update a style [3]. Before, the style resource (SLD file or example) was updated and then the catalog object was updated, this means that someone listening on styles catalog modified\post-modified events could safely assume that the style object and the associated resources were updated. The JMS community module was expecting this behavior.
My first question is: should this be considered a regression ?
In my opinion the old behavior makes sense, if I get an event from the catalog saying that a style was updated I would say it makes sense to assume that the associated resource was also updated.
An alternative fix could be not changing the order in which the operations are performed, but instead persist the style resource using the old style path and let the GeoServer persister do is job. This will fix the issue and preserve the old behavior, which makes sense to me.
Sorry for not detecting this when the PR was done and bring this now.
Opinions on this ?
Nuno Oliveira
[1] https://github.com/geoserver/geoserver/pull/2075
[2] https://osgeo-org.atlassian.net/browse/GEOS-7930
[3] https://github.com/geoserver/geoserver/blob/master/src/web/wms/src/main/java/org/geoserver/wms/web/data/StyleEditPage.java#L111-L120
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
