On Thu, Apr 9, 2015 at 12:28 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Kevin has tracked down the duplication for GEOS-6971
<https://osgeo-org.atlassian.net/browse/GEOS-6971> (see #1010
<https://github.com/geoserver/geoserver/pull/1010> ) and patched the
geoserver copy of the schema file.
We still have duplication between the following two files:
GeoServer: StyledLayerDescriptor.xsd
<https://github.com/geoserver/geoserver/blob/master/src/main/src/main/resources/schemas/sld/StyledLayerDescriptor.xsd>
GeoTools: StyledLayerDescriptor.xsd
<https://raw.githubusercontent.com/geotools/geotools/83e50a7ca63f11227d5840463c105ddf6a44330a/modules/extension/xsd/xsd-sld/src/main/resources/org/geotools/sld/bindings/StyledLayerDescriptor.xsd>
Since both these schemas are embedded in a jar is it possible to access
them as a class resource (and avoid the duplication)?
I guess we could, but you have to consider those schemas in GeoServer pull
double duty:
* Internal validation
* Published for the world to download (useful when the server and its
clients are isolated, e.g., miltary network)
So, doable, but you also have to preserve the second duty (publishing),
which right now is performed by
simply putting those files in a schemas package that automatically gets
published on the net.
Each important schema can be found in resources/schemas/..., e.g.:
https://github.com/geoserver/geoserver/tree/master/src/wms/src/main/resources/schemas/wms
https://github.com/geoserver/geoserver/tree/master/src/wfs/src/main/resources/schemas/wfs
This is done by ClasspathPublisher, in gs-ows, we'd need something similar
to extract from the GeoTools
xsds, but something that remaps the current published locations, which
should not change for backwards
compatibility, back into a GeoTools package structure.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
