[Geoserver-devel] "Styles" for layer groups
in this mail I’d like to discuss adding a notion of “styles” for layer groups, as in, named styles that client can use against
the layer group.
First, those styles would make sense only if the group is “single” or “opaque”, that is, setup so that one cannot see its contents,
making it look like any other layer. And like any other layer, the client would be able to request a named, non default style for it.
Configuration wise, these styles would have a name and a configuration, which would not just be a different set of styles
for the layers in the group, but really a separate set of layer and styles (the user would be none the wiser).
The current configuration would be retained as the default un-named style (for upgrade sake), and a map of names
to layers/style containers would be added to support alternative styles.
The code exploding layers would have to be upgraded, as well as everything dealing with removal of layers/style
(one more set of affected config to search into).
I tried to picture in my mind a way to set this up as a community module too (some play over non advertised groups
and changing the request on the fly), but considering how tricky it would be, and
that styles need to be advertised in capabilities too, core would seem to be a better place.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Functionality-wise, I can see how this would be useful.
This seems to have some overlap with the work that was done for GSIP-161, you may be able to take advantage of some of that (or will have to work around it).
I’d be interested to see more detail about how you plan to implement this, as its not quite clear to me from your description (In particular “a separate set of layer and styles” sounds a lot like what a layer group already is).
Another concern I have - if this is all abstracted away from the user, to the point that the layer group is acting like any other layer, what happens if they try to use a regular style with one of these layer groups (or try to use a layer group style with a regular layer)? It seems like this could be a potential point of confusion.
Torben
On Thu, Mar 8, 2018 at 7:05 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
the layer group.
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Hi Torben,
thanks for you reply, comments inline:
On Thu, Mar 8, 2018 at 7:50 PM, Torben Barsballe <
<https://github.com/geoserver/geoserver/wiki/GSIP-161&gt;, you may be able
Noted
I'd be interested to see more detail about how you plan to implement this,
as its not quite clear to me from your description (In particular "a
separate set of layer and styles" sounds a lot like what a layer group
already is).
Basically, you have one named layer that matches a configured layer group.
And then inside you have N configurations for layers and groups, associated
to different style names that the user can call.
UI configuration wise not much will change, just a dropdown to choose the
"style" configuration you want to edit on top of the layer/style table, and
maybe a quick way to create a new one by copy.
The default one will have "no name", empty, just like it is now.
Nothing will change in this regards. Consider the spearfish group:
https://demo.geo-solutions.it/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=spearfish&styles=&bbox=589425.9342365642,4913959.224611808,609518.6719560538,4928082.949945881&width=768&height=539&srs=EPSG:26713&format=application/openlayers
If I hit it with a normal layer style, it gets ignored:
https://demo.geo-solutions.it/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=spearfish&styles=polygon&bbox=589425.9342365642,4913959.224611808,609518.6719560538,4928082.949945881&width=768&height=539&srs=EPSG:26713&format=application/openlayers
About the layer group "styles", trying to use them against a normal layer
will result in a "style not found" exception, since they are not really
styles,
just different configuration of a layer group, so GeoServer won't find them.
We could call them "configurations" if you like, but the user visible
effect from the point of view of someone using a desktop client, or any
OGC compliant client, is that a new set of named styles will appear in the
capabilities document attached to the group named layer,
and they will be able to choose one of them getting back a different view.
WMS wise that works fine, WMS does not tell you what's inside a layer, and
does not tell you how a named style is implemented (does not have to be
SLD).
The confusion, might be from inside because we call "style" a StyleInfo
object, whilst in this case it will just be a reference to a different
group configuration, but this can be clearly documented.
Makes sense?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
Thanks for the more detailed explanation, that makes sense.
I’ve got no other concerns.
Torben
On Fri, Mar 9, 2018 at 7:06 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
On Thu, Mar 8, 2018 at 7:50 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Noted
And then inside you have N configurations for layers and groups, associated to different style names that the user can call.
UI configuration wise not much will change, just a dropdown to choose the “style” configuration you want to edit on top of the layer/style table, and maybe a quick way to create a new one by copy.
The default one will have “no name”, empty, just like it is now.
About the layer group “styles”, trying to use them against a normal layer will result in a “style not found” exception, since they are not really styles,
just different configuration of a layer group, so GeoServer won’t find them.
We could call them “configurations” if you like, but the user visible effect from the point of view of someone using a desktop client, or any
OGC compliant client, is that a new set of named styles will appear in the capabilities document attached to the group named layer,
WMS wise that works fine, WMS does not tell you what’s inside a layer, and does not tell you how a named style is implemented (does not have to be SLD).
The confusion, might be from inside because we call “style” a StyleInfo object, whilst in this case it will just be a reference to a different group configuration, but this can be clearly documented.
Makes sense?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks a lot Torben.
Anyone else has feedback? Since it’s a change in the core API a small proposal is due, would like to avoid seeing
it derailed (I’m trying to do these discussions beforehand to avoid large last minute changes happening
after an agreement with the sponsor of this functionality and the community has apparently been reached).
On Fri, Mar 9, 2018 at 5:57 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Andrea,
Torben
Hi Torben,
Noted
Makes sense?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
I am really happy to see this functionality added!
I understand what is being done, and I can see how it a minimal change. I think it will be a bit hard to explain, along with the different tree modes etc…
I had previously thought of a different UI approach but it is not as functional.
Hi Andrea,
Torben
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Torben,
Noted
Makes sense?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
An useful improvement indeed, and I agree that’s this should go to core.
On Fri, Mar 9, 2018 at 5:57 PM, Torben Barsballe <tbarsballe@…3839…> wrote:
Hi Andrea,
Torben
On Fri, Mar 9, 2018 at 7:06 AM, Andrea Aime <andrea.aime@…1268…> wrote:
Hi Torben,
Noted
Makes sense?
Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Andrea Aime
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Jody Garnett
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
