[Geoserver-devel] Styling (GeoTIFF) coverages
What is the current status of the RasterSymbolizer? Which types of
coverage can use an SLD? Of the supplied demo's using GeoTIFF, none
seem to be rendered using the raster.sld.
The tutorial:
  http://docs.codehaus.org/display/GEOSDOC/User+Tutorial+Coverage
tells you to select the 'raster' style, but the image preview at the end
clearly is not rendered using the raster.sld, it simply uses the colours
from the sample.tiff.
Also note that the raster.sld as distributed in 1.5-RC1 does not
validate against the SLD schema.
-- Gertjan van Oosten, gertjan@anonymised.com, West Consulting B.V., +31 15 2191 600
Hi Gertjan,
The tutorial:
I just tried this out and it seemed to work ok. Questio:. When setting
the style to raser, did you click "Submit", and then "Apply" -> "Save".
( Our UI workflow is far from perfect :slight_smile: ).
Confirmed. I have committed the changes to the style.
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi Justin,
As quoted from Justin Deoliveira <jdeolive@anonymised.com>:
Well, I just tried e.g. this one from the supplied demo's on a fresh
Geoserver 1.5-RC1 install:
  http://localhost:8080/geoserver/preview/nurc_~gtiff172030523_192_106_197_2_0.html
and it was still a grayscale map, i.e. not using raster.sld; to wit:
  % gdalinfo -mm webapps/geoserver/data/coverages/geotiff_sample/~gtiff172030523_192_106_197_2_0.tiff
  Driver: GTiff/GeoTIFF
  Size is 512, 513
  Coordinate System is:
  GEOGCS["WGS 84",
      DATUM["WGS_1984",
    SPHEROID["WGS 84",6378137,298.2572235629972,
        AUTHORITY["EPSG","7030"]],
    AUTHORITY["EPSG","6326"]],
      PRIMEM["Greenwich",0],
      UNIT["degree",0.0174532925199433],
      AUTHORITY["EPSG","4326"]]
  Origin = (-98.982384,49.058823)
  Pixel Size = (0.09631848,-0.09631922)
  Metadata:
    AREA_OR_POINT=Area
  Corner Coordinates:
  Upper Left ( -98.9823837, 49.0588226)
  Lower Left ( -98.9823837, -0.3529377)
  Upper Right ( -49.6673203, 49.0588226)
  Lower Right ( -49.6673203, -0.3529377)
  Center ( -74.3248520, 24.3529425)
  Band 1 Block=512x16 Type=Byte, ColorInterp=Gray
      Computed Min/Max=0.000,255.000
which does not seem to match with raster.sld:
  <ColorMapEntry color="#7deb32" quantity="0" label="values"/>
  <ColorMapEntry color="#78c818" quantity="30" label="values"/>
  <ColorMapEntry color="#38840c" quantity="105" label="values"/>
  <ColorMapEntry color="#2c4b04" quantity="300" label="values"/>
Similarly for the sample from the coverage tutorial.
Questio:. When setting the style to raser, did you click "Submit", and
Of course. I followed the tutorial to the letter. :wink:
Good.
Kind regards,
On 2/22/07, Gertjan van Oosten <gertjan@anonymised.com> wrote:
Hi Justin,
Hi guys:
AFAIK, the RasterSymbolizer doesn't work for styling yet. But you
never know--Alessio may have something that works stashed away :slight_smile:
Alex
Ciao Gertjan,
truth is the support for RasterSymbolization is pretty bad as of now.
It was made as a quick hack to work with GTOPO and ArcGrid a while
ago.
It is in the plans to improve RasterSymboler support in GeoServer, but
unless someone comes up with some funding I don't think I will be able
to work on this before the end of March.
Simone.
Hi Justin,
  Size is 512, 513
  GEOGCS["WGS 84",
      DATUM["WGS_1984",
  Metadata:
    AREA_OR_POINT=Area
  Corner Coordinates:
Good.
Kind regards,
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-devel mailing list
Eng. Simone Giannecchini
President /CEO GeoSolutions
Whoops, sorry Gertjan, I got confused as to what the original problem
was. Thanks Alex!!
-Justin
Hi Justin,
Hi guys:
Alex
!DSPAM:1004,45ddb56b301091804284693!
Justin Deoliveira
Alexander, Justin, Simone,
Truth is the support for RasterSymbolization is pretty bad as of now.
ago.
Fair enough. It would be helpful if this is advertised somewhere so
people wouldn't spend their time chasing ghosts. In particular the
Coverage Tutorial:
could mention that fact in Step 1[*], near the point where you are
supposed to select a style.
[*] That's meant as a joke BTW, it only has "Step 1" now. :wink:
Is there a JIRA issue to track this? I couldn't find one...
Kind regards,
ago.
Coverage Tutorial:
Good point, I have put a warning in the tutorial and link a jira item
for details.
There is now :slight_smile:
http://jira.codehaus.org/browse/GEOS-932
Kind regards,
Justin Deoliveira
ago.
Coverage Tutorial:
oops!, I changed it... now there are 3 steps =)
Kind regards,
Brent Owens
(The Open Planning Project)
