On Sat, Jun 27, 2015 at 9:44 AM, Simone Giannecchini <
simone.giannecchini@anonymised.com> wrote:
Ciao Gabriel,
IMHO it would be better to have this as a separate plugin since GS it's
already big enough.
If needed I can talk to Andrea and see if he has some time to help with
this.
Gabriel, could share some description of the extra UI you need to make
pluggable?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
