There are still some things that could be added (namely a REST endpoint for generating styles, and the ability to specify the style generation for an import), but the core change has been implemented here.
For the REST endpoint, I don’t have a lood of experience working with the REST code, and am not sure I will have enought time to sort it out this week.
Modifications to the importer may be better suited while/after implementing support for sidecar styles. I am still trying to figure out the best method to implement format selection for the importer. Style generation is done when the tasks are initialized, fairly early in the import process (during createContext). Without an API change, the only viable method seems to be modifying the generated styles after creating the context (which seems a bit inefficient).
As part of this Pull Request, it is possible to programatically change the StyleHandler used by Importer to generate the style, but this affects all imports, and is therefore only viable in cases where (a) all generated styles use the same format or (b) a single user has complete controll over when import requests are submitted.
On Mon, Aug 10, 2015 at 5:05 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Jody - those refer to the same point; I updated the proposal after that email was sent.
Torben
On Mon, Aug 10, 2015 at 4:56 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
+1
Some additional discussion follows…
On 10 August 2015 at 15:59, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Jody - It should be fairly easy to get importer to recognize style files: simply iterate through StyleHandlers to get the supported formats/extensions, and see if there are any matching files in the import. Such a change would be entirely distinct from the style generator.
Right - you are correct StyleHandler includes the file extension
Given that this does involve an API change to StyleHandler in gs-main, I have created a GSIP here: https://github.com/geoserver/geoserver/wiki/GSIP-131
I am also considering some other related improvements that may be usefull:
Allow importer to generate files of any format.
Allow style UI to generate styles.
Expose rest endpoint for generating styles.
Your proposal already indicated “Add a new Generate from template style section to the New/Edit Style page, with a drop-down menu to select a template and a link to generate the style.”.
Is this different from “Allow style UI to generate styles” above?
Jody
Torben
On Mon, Aug 10, 2015 at 11:11 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
No problems, but perhaps a related request for importer / style generation.
uDig ships sample data with a sld sidecar file next to each shape file. I would really like it if importer could recognize sld or css sidecar files.
On Mon, Aug 10, 2015 at 10:18 AM Andrea Aime <andrea.aime@anonymised.com268…> wrote:
Geoserver-devel mailing list
Jody Garnett
On Mon, Aug 10, 2015 at 7:03 PM, Torben Barsballe <tbarsballe@anonymised.com3839…> wrote:
The gs-importer extension generates default SLD styles for imported layers.
I would like to extend this functionality to support style generation for arbitrary formats.
This would involve:
Migrating org.geoserver.importer.StyleGenerator to the gs-main catalog package
Adding a generate() method to org.geoserver.catalog.StyleHandler, using StyleGenerator to generates a format-specific style based on a template.
This change would allow us to define default templates for CSS styles (and other extended formats) upon import. Since CSS has a rather different stucture than SLD, this would provide a better default style than generating SLD and immediately converting to CSS in cases where CSS was used (Importer would still default to generating SLD).
This functionality might also be usefull when creating new styles in the geoserver styles page - upon creating a new style, a default template for that format could be loaded.
Given that this involves an API change to gs-main, I intend to get this in before the Aug 18 code freeze.
Does anyone have any concerns or objections to this change?
Not me, looking forward to see the pull request
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
