Yes this helps, thank you!
From: Andrea Aime <andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>>
Date: Tuesday, February 3, 2015 at 11:15 AM
To: sylvia charchut <sylvia.charchut@anonymised.com<mailto:sylvia.charchut@anonymised.com153…>>
Cc: "geoserver-devel@lists.sourceforge.net<mailto:geoserver-devel@anonymised.comrceforge.net>" <geoserver-devel@lists.sourceforge.net<mailto:geoserver-devel@lists.sourceforge.net>>
Subject: Re: [Geoserver-devel] Supported method for publishing coverages?
On Tue, Feb 3, 2015 at 6:03 PM, Sylvia Charchut <Sylvia.Charchut@anonymised.com<mailto:Sylvia.Charchut@anonymised.com>> wrote:
Hello Dev-list,
I have a startup listener in geoserver and from this class I publish layers through the use of the catalog & catalog builder like this:
LocalWorkspaceCatalog catalog = (LocalWorkspaceCatalog) GeoServerExtensions.bean("catalog");
CatalogBuilder builder = new CatalogBuilder(catalog);
CoverageStoreInfo store = catalog.getCoverageStoreByName(name);
builder.setStore(store)
for(String coverageName: coverages){
CoverageInfo ci = builder.buildCoverage(coverageName);
layerInfo layer = builder.buildLayer(ci);
layer.setResource(ci);
catalog.add(ci);
catalog.add(layer);
Is this method of publishing supported? Or are the only ways of publishing through the rest api and web interface?
The method seems valid. I don't know what exactly to say about "supported" though.
GeoServer is a "end user" application, often customized in various ways, but not really though to be
a library or a base application (like, we don't have a firm API control, even if we try to avoid gratuitous
changes).
As a programmer, you're supporting yourself there... and yes, the API you are using there is important, used
in many places, so it's unlikely, but not impossible, to be changed over time.
Hope this helps.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
